- Thank you received: 2098
cold weather vs carburetor
23 Jan 2013 13:06 - 23 Jan 2013 13:13 #568822
by Patton
...mechanically sync'd.... -- aka bench sync'd -- the baseline setting to equalize throttle slide positions.
As known, a "running" sync -- which is the actual sync operation -- is thereafter required to equalize low rpm performance among the cylinders, with each cylinder's performance being measured by carb vacuum. And which "running" sync usually results in slightly varying throttle slide heights among the carbs to produce equivalent low rpm performance among the cylinders.
An objective of the running carb sync is to achieve the smoothest possible low rpm performance at idle, followed by strong and steady "pull-away" performance from idle.
Smooth equivalent performance among the cylinders also significantly reduces cam chain noise.
Replied by Patton on topic cold weather vs carburetor
Freekz1000 wrote: The stock airbox went back on last night. I pulled the carbs and mechanically sync'd them....
Last edit: 23 Jan 2013 13:13 by Patton.
- wireman
- Thank you received: 299
24 Jan 2013 02:12 #568904
by wireman
Replied by wireman on topic cold weather vs carburetor
Maybe it has nothing to do with air temp,if it was all just gone through you probably just need to spend some time checking/fine tuning things.
Thats normal
Thats normal
- mick z1a
- Thank you received: 11
24 Jan 2013 04:18 #568914
by mick z1a
Replied by mick z1a on topic cold weather vs carburetor
where's MN?
- donthaveakawman
- Visitor
24 Jan 2013 04:56 #568917
by donthaveakawman
Replied by donthaveakawman on topic cold weather vs carburetor
thinking about finding some fasteners and t-fittings to link my pods and clean air flap-trap all together.
- pete greek1
- Thank you received: 185
24 Jan 2013 10:52 #568937
by pete greek1
Replied by pete greek1 on topic cold weather vs carburetor
Mick, MN. is Minnisota
