bike runs bad at full throttle... what's wrong????
- 00.
- 1973 kawasaki z1
05 Nov 2012 04:33 - 05 Nov 2012 04:35 #557095
by 00.
1973 kawasaki z1
Replied by 00. on topic bike runs bad at full throttle... what's wrong????
Well I fixed my problem,,,,, it was a stupid spark plug wire, the wire was lose at the point where it connect to the cap... I cheked for spark at the spark plugs but it always looked good, the only way I found the loose wire is when I recheck the timing I decided put the timing gun on every wire just to see if the timing is good, and when I put it on number 3 the light would come one iregularly..... I'm so glad the bike runs right now,,,, Now I can't keep the front end on the ground every time I hit 5th gear :woohoo:
1973 kawasaki z1
Last edit: 05 Nov 2012 04:35 by 00..
- Motor Head
- Thank you received: 391
05 Nov 2012 10:31 #557100
by Motor Head
Replied by Motor Head on topic bike runs bad at full throttle... what's wrong????
Good to hear.
You can get new solid core wire by the foot at most auto parts stores, 7mm, about .80 cents a foot. If they screw on at the coil as well, I'd replace the wires. Many have up graded from the old stock coils to Accel or Dyna. Much better than having those old coils for sure.
