bike runs bad at full throttle... what's wrong????
- 00.
- 1973 kawasaki z1
1973 kawasaki z1
- Del_Herring
- Thank you received: 29
1983 KZ750-N2 Spectre
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
aside form that ...can you nurse them up to speed...can you upshift and get the bike running along....or is when you dump the throttle form like half speed....
also you may really have 76 kz900 and not a z1...unless the carbs look the same as the early ones they are going to be 26mm kz900 carbs
oh and pictures posted,when switching parts and naming models and parts, help folks not type answers that could be avoided in a simple picture
bike,carbs,new carbs....pictures
1976 KZ900
2003 ZX12R
2007 FZ1000
- Motor Head
- Thank you received: 391
- 00.
- 1973 kawasaki z1
]Del_Herring... Have you synced them?
Yes I did sinc them
do you have a new battery.....
Battery is good shows 12.9 volts
I can't get the bike up to speed it realy won't go faster than 50mph, it really boges down and just sounds like you put a sock in the exhaust pipes, serious power loss, but I can drive below 3000rpms fairly comfortably.
trianglelaguna... also you may really have 76 kz900 and not a z1...unless the carbs look the same as the early ones they are going to be 26mm kz900 carbs
They are definetaly 1975 carbs, and the bike is definetaly a 1975 bike, I did have the 1974 28mm carbs on the bike, and it ran perfectly, the 1975 carbs are also 28mm carbs
Motor Head... Fuel level in the float bowls, must be set correctly. This effects the entire carb operation. Also if all the stock jets are installed for that set of carbs on your model bike, did you also set the needle clip position to stock (usually middle notch)?
Will recheck the floats today, but the jetting is definetally correct double check it on the book and online information and it checks out all ok, I checked the main jet size, secondary jet size, needle clip hight, the correct amount of turns on the air jet, and I even check the part number on the carb slides, it all checks out, and is all correct.....
Not really sure on what to do next on this....
1973 kawasaki z1
- trianglelaguna
other than that i'm stumped....good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- 4TheKZ1000
- Visitor
full throttle is main jet
I had a flat spot on mine from 3/4 to full.....went up one on jet needle and up 2 on main jet sizes....bike came around and pulled strong with no adverse effects....my setup is very different but this corrected mine.
- Motor Head
Main jet sizes would be the same I would think, unless the Air Jet in the Airhorn/ Belmouth is smaller. Needle and Needle Jet might be different, and work together.
Have you pulled the plugs to see if it looks either lean or rich?
Did you make any other changes when you Installed the different carbs? Ignition? Did it sit for a while, maybe the ignition Advancer is stuck? Condenser fail?
To help rule out other issues, putting back to the other set up as before would rule out or confirm other issues.
- Kitten Tooth
- Thank you received: 10
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
Kitten Tooth wrote: I had a similar problem with a 1981 KZ1000CSR. Try romping up the street and when it starts to run badly, pull the choke and see if it gets better for a second. This will rule out anything else but the carbs. The carbs on the CSR i was working on had lots of crud all over the little screens that filter the gas going through the need/seat valves inside all 4 carbs. It was filling the carbs enough to run good and go up the street but once you hit about 5000RPM it started to sputter really bad like it had a rev limiter or something and the fuel flow couldn't keep up with fuel consumption. After i cleaned up the seats i couldnt keep the front end on the ground
Good post right there KT.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
