- Thank you received: 52
Center Tee leaking on 29's, FIXED!!!
- kzz1king
Wayne
Home built KZ1000 turbo setup
- wireman
- Thank you received: 299
- 4TheKZ1000
- Visitor
www.z1enterprises.com/ItemDetails.aspx?i...+Ring&item=MA002-617
www.z1enterprises.com/ItemDetails.aspx?i...hbore&item=ZSM26-269 you can see 4 o-rings needed.
- kzz1king
Wayne
- wireman
- kzz1king
wireman wrote: Yeah its a pita to pull em off the rack in my experiance anyway,id rather buy another set of carbs and rebuild them before trying that again
Oh wait,if theyre 29s I guess Id make the sacrifice and fix them! :woohoo:
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- kzz1king
Wayne
4TheKZ1000 wrote: not to big...have to come off and need to loosen screws on backing plate for 3 and 4 to move carbs around to get tee out.....just need to replace 4 o-rings and put back toghter. Get o-rings from Z1E. Ive got some exp with 29's.
- 4TheKZ1000
- Visitor
- kzz1king
Wayne
- wireman
- 4TheKZ1000
- Visitor
