Center Tee leaking on 29's, FIXED!!!
24 Sep 2012 23:06 - 13 Oct 2012 20:07 #550693 by kzz1king
Center Tee leaking on 29's, FIXED!!! was created by kzz1king
Got a chance to give the carbies a good workout today and all is well,except the rear tire is a little smoother :woohoo: Let it sit with the gas on and no spills or thrills. 2 new needle/floats later and all is good. Thanks all.Unfortunately our season is at an end.
Wayne
Home built KZ1000 turbo setup
Last edit: 13 Oct 2012 20:07 by kzz1king.
  • wireman
24 Sep 2012 23:10 #550696 by wireman
Replied by wireman on topic Center Tee leaking on 29's, How difficult?
Yeah its a pita to pull em off the rack in my experiance anyway,id rather buy another set of carbs and rebuild them before trying that again B)
  • 4TheKZ1000
  • Visitor
24 Sep 2012 23:10 - 24 Sep 2012 23:29 #550697 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Center Tee leaking on 29's, How difficult?
not to big...have to come off and need to loosen screws on backing plate for 3 and 4 to move carbs around to get tee out.....just need to replace 4 o-rings and put back toghter. Get o-rings from Z1E. Ive got some exp with 29's.
www.z1enterprises.com/ItemDetails.aspx?i...+Ring&item=MA002-617
www.z1enterprises.com/ItemDetails.aspx?i...hbore&item=ZSM26-269 you can see 4 o-rings needed.
Last edit: 24 Sep 2012 23:29 by 4TheKZ1000.
24 Sep 2012 23:10 #550698 by kzz1king
Replied by kzz1king on topic Center Tee leaking on 29's, How difficult?
One more thing, anyone have any luck sourcing the o rings at an auto parts store? I have been paying more for shipping lately than for parts on these carbs.
Wayne
  • wireman
24 Sep 2012 23:11 - 24 Sep 2012 23:59 #550699 by wireman
Damn double posting #$^% computer! :sick: :woohoo:
Last edit: 24 Sep 2012 23:59 by wireman.
24 Sep 2012 23:42 #550708 by kzz1king
You had me worried for a minute :woohoo:
wireman wrote: Yeah its a pita to pull em off the rack in my experiance anyway,id rather buy another set of carbs and rebuild them before trying that again B)
Oh wait,if theyre 29s I guess Id make the sacrifice and fix them! :woohoo:
24 Sep 2012 23:43 #550710 by Mark Wing
Replied by Mark Wing on topic Center Tee leaking on 29's, How difficult?
Try putting some laquare thinner in the carbs and let it fill the line over the tee. It's fixed a leaky tee for me in the past.
Mark
Yorba Linda Cal.
24 Sep 2012 23:46 #550711 by kzz1king
Do I need to remove or loosen anything besides the screws that hold the carbs on? Enricher rod? Throttle rod? Thanks
Wayne
4TheKZ1000 wrote: not to big...have to come off and need to loosen screws on backing plate for 3 and 4 to move carbs around to get tee out.....just need to replace 4 o-rings and put back toghter. Get o-rings from Z1E. Ive got some exp with 29's.
  • 4TheKZ1000
  • Visitor
25 Sep 2012 00:01 - 25 Sep 2012 00:06 #550719 by 4TheKZ1000
you should be ok....if you need more room...work on 4, remove carb top a disconnect throttle rod bolt from rod..... slide carb out of way. the enrinch rod not a issue will slide off fingers. Will need to work from outside in for clearance
Last edit: 25 Sep 2012 00:06 by 4TheKZ1000.
25 Sep 2012 11:27 #550766 by kzz1king
THANKS 4theKZ. You know I never had no trouble till some guy called Wireman told me to put chapstick on my gaskets ;) Must have been the grape flavor that did it.
Wayne
  • wireman
25 Sep 2012 12:57 #550779 by wireman
:laugh: :laugh: :laugh: :laugh: :laugh:
  • 4TheKZ1000
  • Visitor
25 Sep 2012 14:22 #550786 by 4TheKZ1000
The NFL just upheld WIREMAN'S chapstick call.... :woohoo: :woohoo: :woohoo: :woohoo:
