KZ250 Single; Starts, revs itself, pops, dies
- XXWoodmanXX
Is it running too rich? The pet cock operates properly and does not leak. Fuel filter right near the carb is clean and free of blockage, and I can see the fuel level inside. I know for a fact I am getting spark. I don't have the points ignition, it's an Ignition module box (just to re-iterate, as I've been asked already)
Any idears? Any questions, please feel free to ask. Thanks!
- trianglelaguna
- Thank you received: 235
look in the book for the carb diagram and make sure you find the idle circuit and clear it
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- XXWoodmanXX
cycles.evanfell.com/2008/09/how-to-clean...retor-the-right-way/
But I don't have a compressor, so I really just let it drip dry of WD40 after I cleaned all the lemon juice off it. I'll do the process over and be sure to clean it and find a way of blowing the passages out, then try again. Thanks!!
- Thank you received: 2098
The main idea is to assure pilot mixture flow into the carb throat.
Being able to fiddle with the choke to keep it running indicates that some fuel mixture is getting into the carb throat via the separate choke circuit.
And WEAR EYE PROTECTION while spraying, because the spray always backfires, ALWAYS.
- XXWoodmanXX
Is this a lean condition? Would this be due to a low fuel level in the bowl? I'm totally confused as to what it could be.
- P21
- Thank you received: 34
Kawasaki KZ 1000 Police (2002) P21
- XXWoodmanXX
FYI, is it supposed to have the rubber plug over the jet itself, correct?? It's a Keihin 34mm carb
- P21
main jet is the big one in middle of carb
- P21
- XXWoodmanXX
- XXWoodmanXX
P21 wrote: one other thing what is your air mixture screw set at?
Errrrr, where is this located? lol
Again, from what I gather, I have a Keihin CVK 32mm
EDIT: I may also look into replacing my in-line fuel filter, to see if that's the possible issue as well, as it sounds like I might be starving my carb
