Carb. Boot Replacement???
03 Sep 2012 12:30 #546367 by bl_francis
Carb. Boot Replacement??? was created by bl_francis
When I replace these do I put some kind of liquid gasket on then? The old ones have some kind of goop on them.
Attachment ImageUploadedByTapatalk1346686138.502518.jpg not found
Attachment ImageUploadedByTapatalk1346686176.972675.jpg not found
1987 KZ1000 Police
03 Sep 2012 12:48 #546372 by mtbspeedfreak
Replied by mtbspeedfreak on topic Carb. Boot Replacement???
High temperature silicone to seal. I use "The Right Stuff" by 1 minute gasket.
2000 ZRX 1100
1976 KZ 900- Daily Driver
03 Sep 2012 13:13 #546379 by bl_francis
Replied by bl_francis on topic Carb. Boot Replacement???
Thanks very much !
1987 KZ1000 Police
03 Sep 2012 16:09 #546416 by 650ed
Replied by 650ed on topic Carb. Boot Replacement???
I put them on dry and they don't leak. Ed
03 Sep 2012 17:04 #546428 by P21
Replied by P21 on topic Carb. Boot Replacement???
650ed wrote: I put them on dry and they don't leak. Ed
+1 here
Kawasaki KZ 1000 Police (2002) P21
03 Sep 2012 22:54 #546495 by mtbspeedfreak
I ride in 110 degree weather and don't want the boots warping or shrinking, so I put the silicone on as added insurance.
2000 ZRX 1100
03 Sep 2012 23:41 #546513 by RonKZ650
Replied by RonKZ650 on topic Carb. Boot Replacement???
I don't like RTV or silicon sealer which I guess is the same thing. Most gaskets seal fine without aid of this stuff and the intakes don't need it. Factory didn't use a sealer, so what you got there is added by someone.
04 Sep 2012 10:26 #546562 by martin_csr
Replied by martin_csr on topic Carb. Boot Replacement???
mtbspeedfreak wrote: I ride in 110 degree weather and don't want the boots warping or shrinking, so I put the silicone on as added insurance.
Since the engine gets so hot, wouldn't the ambient temperature be irrelevant in regards to the carb holders?
The following user(s) said Thank You: BlackZ1R
  • BlackZ1R
  • Kawasaki in my blood
04 Sep 2012 10:52 #546566 by BlackZ1R
Replied by BlackZ1R on topic Carb. Boot Replacement???
+1 good posting. New manifolds go on dry. USe no sealer on them. DO NOT use silicon on anything pertaining to the fuel system. Sorry MTB, it's just not a good idea.
The reason your manifolds have the sealer on them is because they are old, and cracked, and warped. They were leaking. It appears to be Three Bond on them, which is not RTV silicon, and will work in this application. Although it is a temporary fix.
New manifolds are soft and pliable. They seal without the aid of sealers.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • 4TheKZ1000
  • Visitor
04 Sep 2012 11:08 #546570 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Carb. Boot Replacement???
put on DRY as your great grandaddy's skull
04 Sep 2012 12:19 #546587 by mtbspeedfreak
The engine runs hotter when it's that hot. When I rode to Cabo in the middle of July last year, the bike ran like crap until I sealed up the boots because they warped or cracked;115 in the middle of the day, absolutely miserable.
The Right Stuff is as chemically resistant as a silicone based compound can get. If it's applied, however, wait a full 24 hours to make sure that everything is cured.
2000 ZRX 1100
04 Sep 2012 12:21 #546588 by mtbspeedfreak
I'm working off of my phone, where are you located Frances? You likely don't need to use sealer, especially if you aren't riding in temperature.
2000 ZRX 1100
