- Thank you received: 10
Carb. Boot Replacement???
- bl_francis
Attachment ImageUploadedByTapatalk1346686138.502518.jpg not found
Attachment ImageUploadedByTapatalk1346686176.972675.jpg not found
1987 KZ1000 Police
- mtbspeedfreak
- Thank you received: 36
2000 ZRX 1100
1976 KZ 900- Daily Driver
- bl_francis
- Thank you received: 2829
- P21
- Thank you received: 34
650ed wrote: I put them on dry and they don't leak. Ed
+1 here
Kawasaki KZ 1000 Police (2002) P21
- mtbspeedfreak
2000 ZRX 1100
- RonKZ650
- Thank you received: 241
- Thank you received: 1656
Since the engine gets so hot, wouldn't the ambient temperature be irrelevant in regards to the carb holders?mtbspeedfreak wrote: I ride in 110 degree weather and don't want the boots warping or shrinking, so I put the silicone on as added insurance.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
+1 good posting. New manifolds go on dry. USe no sealer on them. DO NOT use silicon on anything pertaining to the fuel system. Sorry MTB, it's just not a good idea.
The reason your manifolds have the sealer on them is because they are old, and cracked, and warped. They were leaking. It appears to be Three Bond on them, which is not RTV silicon, and will work in this application. Although it is a temporary fix.
New manifolds are soft and pliable. They seal without the aid of sealers.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- 4TheKZ1000
- Visitor
- mtbspeedfreak
The Right Stuff is as chemically resistant as a silicone based compound can get. If it's applied, however, wait a full 24 hours to make sure that everything is cured.
2000 ZRX 1100
- mtbspeedfreak
2000 ZRX 1100
