Best carburetors?
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
Best carburetors?
20 Aug 2012 18:41 - 20 Aug 2012 18:43
#543693
Obviously there are many variables (cams, compression, displacement, nitrous, aspiration, etc.), but what's the best set of modern carburetors money can buy for these bikes, with money being no object [I wish...]?
Mikuni RS?
Mikuni TMR?
Keihin FCR?
How about stock-ish displacement and compression and street cams, possibly a street port?
Keihin CRS?
Mikuni 29 smoothies?
Mikuni 33 smoothies?
2000 ZRX 1100
1976 KZ 900- Daily Driver
Last edit: 20 Aug 2012 18:43 by mtbspeedfreak.
  • wireman
  • wireman's Avatar
Re: Best carburetors?
20 Aug 2012 22:48
#543753
Id say for after market carbs the cr specials are the most cost affective,that is untill ol Larry develops a plug/play fuel injection system for these old beasts! :woohoo:
  • Tomolu5
  • Tomolu5's Avatar
20 Aug 2012 23:43
#543764
Wish I had that picture of the deer eating popcorn that wireman uses, cause I will be watching this one closely.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • porchev914
  • porchev914's Avatar
20 Aug 2012 23:49 - 20 Aug 2012 23:50
#543766
:woohoo: Yoshimura FCR's :woohoo:
FRANKEN Z!
Last edit: 20 Aug 2012 23:50 by porchev914.
  • wireman
  • wireman's Avatar
20 Aug 2012 23:59
#543769
Tomolu5 wrote: Wish I had that picture of the deer eating popcorn that wireman uses, cause I will be watching this one closely.
Ask and you shall recieve,I stole it from testarossa way back when. B)
  • wireman
  • wireman's Avatar
21 Aug 2012 00:00
#543770
Attachment popcorn_2012-08-20.gif not found
The following user(s) said Thank You: Tomolu5
  • mtbspeedfreak
21 Aug 2012 02:58 - 21 Aug 2012 03:00
#543802
porchev914 wrote: :woohoo: Yoshimura FCR's :woohoo:
Why not Yoshimura TMRs? :silly:
2000 ZRX 1100
Last edit: 21 Aug 2012 03:00 by mtbspeedfreak.
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
21 Aug 2012 09:11
#543830
Can you run bigger carbs on a smaller engine with a restrictor plate? Say for example A z1 900 stock with cr specials.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
21 Aug 2012 10:02
#543836
The key with any modifications is you pick a matched set of components for the application you want.
The answers differ based whether this would be hot street, strip or road-race. For many of the carbs you WILL need the larger cc's, cams and head work to take advantage of them.
Pure performance versus streetable is a key difference. Big carbs, smnall engine and you get very soft low-end and good top-end.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • OldSchoolZ
  • OldSchoolZ's Avatar
21 Aug 2012 11:28
#543848
For street driven bikes, Its hard to beat a CV's smoothness and forgiving throttle.
Setting up a set of smoothbores for an old Z can be a nightmare. There are soooo many variables.
These smoothbores need to be set up for the 900/KZ1000. Air cutaways on the back of the slides. Needles and jet needles vary.Pilot airjets and main air jets also. If they were drilled, even more problems.If you start modifying your engine, then you have to take account for what thats done to your intake flow ect...
Me personally, I'll have a streetbike or a drag bike. I'll slap the turbo on that biatch when Im ready to make speed.
Remember, don't work on your bike so much you never ride it.
  • mtbspeedfreak
21 Aug 2012 15:38
#543924
peter1958 wrote: Can you run bigger carbs on a smaller engine with a restrictor plate? Say for example A z1 900 stock with cr specials.
CR29s should make a stock Z1 run pretty good, no? Aren't they basically a modern design of the Mikuni VM29s? [Please excuse my ignorance]
2000 ZRX 1100
  • OldSchoolZ
21 Aug 2012 16:14
#543933
29's were the hotrod carb for those bikes. Slightly larger than stock.
Anything bigger on a stocker Z is almost too much carb. If you do go with some 29's which you can usually find for around 200 dollars, be sure to call sudco and order new needle jets and jet needles. No sense chasing hidden issues.
