- Thank you received: 10
KZP 1000 Starts and idles fine on full choke…
- bl_francis
20 Aug 2012 02:13 #543554
by bl_francis
1987 KZ1000 Police
KZP 1000 Starts and idles fine on full choke… was created by bl_francis
but as soon as you twist the throttle or reduce the choke it stalls out.
I drained the gas out of the tank and cleaned the tank and flushed it.
I also drained all four carbs using the screws. No impurities were visible in the gas that came out.
I also took apart the petcock valve and cleaned it.
Does anyone have any ideas or can direct me to a helpful thread?
1987 KZ1000 Police
- DiamondSkyBlue1000
- Thank you received: 40
20 Aug 2012 03:02 #543557
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic KZP 1000 Starts and idles fine on full choke…
Welcome!
The carbs on these bikes use an "enrichener" circuit instead of an actual choke. That is, they have a circuit in the carb that feeds additional gas to the engine when the "start" knob (that's what they really call it instead of a choke knob) is pulled out. What does that mean? It means if your bike runs only when the choke knob is pulled out, it is probably running too lean or fuel starved. Could be lots of things. Leaky boots, incorrect float levels, valves out of adjustment... Dirty plugs or a weak spark will exacerbate the problem. Start by pulling those plugs and having a look at them. Make sure your carb boots aren't leaking, that's a common problem on these bikes especially with the new corn-fed gas we run in them. Are you getting any popping or other unsociable behavior out of it? When it is idling with the choke on, is it smooth or does it miss a beat every now and then or rattle? Tried running it with the petcock in the prime position?
The following user(s) said Thank You: bl_francis
20 Aug 2012 03:09 #543558
Forgot to ask the most obvious. You are letting it warm up before you turn off the choke? The later bikes were a bit cold natured because they were tuned on the lean side from the factory to meet EPA and mileage requirements and take a bit to warm up to the point you can take the choke off.
- bl_francis
20 Aug 2012 11:45 #543609
by bl_francis
Thanks for the reply, I really appreciate it!
I forgot to mention that I did pull the plugs and I've attached a pic of them. They don't seem too fouled. I got new ones from a dealership.
The bike runs and idles fine with no pops or skips that I can hear.
We have let it idle for about three minutes. Longer?
Also, after I drained the carbs I started the bike on prime and gave it a lot of throttle with the start knob on. We then switched it to "run".
Thanks again for your help!
1987 KZ1000 Police
Replied by bl_francis on topic KZP 1000 Starts and idles fine on full choke…
Attachment ImageUploadedByTapatalk1345473486.196463.jpg not found
1987 KZ1000 Police
- Thank you received: 2829
20 Aug 2012 12:16 #543613
by 650ed
Replied by 650ed on topic KZP 1000 Starts and idles fine on full choke…
Are you using the stock air filter? Ed
- Thank you received: 2098
20 Aug 2012 12:38 - 20 Aug 2012 12:41 #543618
by Patton
Replied by Patton on topic KZP 1000 Starts and idles fine on full choke…
Just guessing a little, but am uncertain that those Bosch spark plugs are the exact equivalent for NGK B8ES.
Also, if an "R" plug (often signifying a "Resistor" plug) is used with resistor plug wires or a resistor plug cap, the "R" plug likely adds too much additional resistance in the so-called secondary loop, which reduces spark quality, resulting in less efficient combustion.
NGK's "R" plug is BR8ES.
Having used NGK plugs, am unfamiliar with Bosch plugs, or equivalency of Bosch with NGK.
It's perfectly all right to combine solid-core (non-resistor) plug wires with non-resistor plug caps and non-resistor spark plugs. But should expect radio interference.
Stock KZ's use resistor spark plug caps as the only resistance in the secondary loop.
However, any single resistor component may be used if desired, so long as it's only one single resistor component and not more than one resistor component.
In other words, where resistance is desired in the secondary loop, use either resistor wires or resistor cap or resistor plug, but never in combination with one another.
Last edit: 20 Aug 2012 12:41 by Patton.
- baldy110
- Thank you received: 512
20 Aug 2012 14:07 #543636
by baldy110
Replied by baldy110 on topic KZP 1000 Starts and idles fine on full choke…
That is the classic symptom of dirty carbs. Your carbs are dirty and need to be cleaned. Pay particular attention to the idle circuits. By cleaning I mean taking them apart and making sure everything is clean including the small passagways in the carb bodies.
- MFolks
- Thank you received: 540
20 Aug 2012 14:13 #543637
by MFolks
Replied by MFolks on topic KZP 1000 Starts and idles fine on full choke…
I'll post carb 101 and 102, it's cleaning instructions:
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, and adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
Carb Cleaning 101
By M. Shively
- MFolks
20 Aug 2012 14:18 #543639
by MFolks
Carb Cleaning 102
Written by MShively
Most carburetor problems seem to come after the motorcycle was stored or not started for a while. If it won't start or only runs with the choke lever pulled out, you have one or more jets obstructed by gummed or varnished fuel. Notice the enrichening lever...most of the motorcycle carbs have enrichening passages inside the carburetor that WHEN THE THROTTLE IS CLOSED, provide the rich air/fuel mixture to start the engine. If you open the throttle any at all it cuts this enrichening out of the system. So if you are having trouble starting and everything looks ok, see if closing the throttle helps. This does not apply to carbs with a butterfly choke.
To access the jets you will have to take the carbs off the engine. A service manual will be very helpful here for specifications, images of the carburetor, and procedures. Take a float bowl off and remove the jets. Sometimes removing the jets can be difficult because the fuel has gummed or varnished over the parts. If so, clear as much of the gum out as possible. Use carb cleaner and compressed air to aid removal. Before soaking carbs in a dip tank or powerful cleaner, look for rubber seals, O'rings, and other parts that may be damaged by the cleaners. Remove any rubber parts prior to cleaning. Look closely, sometimes these parts are hard to see. If they are there and you can't get them, you will have to clean the carb body carefully by hand and not soak it.
Before you remove the fuel/air screw, gently turn it in until it seats. Count and record the number of "turns in." After cleaning and when you replace it, set it at this setting. Most carbs have a rubber o-ring and steel washer under the fuel/air screw spring. Look for them and remove them with a piece of wire or suitable fabricated tool BEFORE you spray carb cleaner in there. The fuel/air screw may be covered by a tamper cap or plug. You will have to remove this plug to access it. Upon reassembly and after cleaning, a base setting for the fuel/air screws of 1.25 turns out is good to start if you don't have the factory specs or forgot to record the turns out earlier. When the engine is warm, turn the screw in until the engine stumbles, then out until it stumbles, and leave it at half way in between. Adjust the idle with the throttle stop screw as needed.
You will need to remove the main jet and the needle jet. The main jet is usually larger and screwed onto the lower end of the needle jet, locking it into the emulsion tower and carb body. Remove the main jet and tap out the needle jet. Do this very carefully. It is soft brass and may break or damage very easily. Sometimes the needle jet will have an O-ring. Remove the O-ring and soak both main jet and needle jet in carb cleaner. Upon reassembly, there may be a locator pin in the emulsion tower/carb body that fits in a grove on the needle jet. Make sure they align properly.
You will need to remove the pilot jet. Pilot jets may be located similar as the main jet, covered by a rubber plug, deep inside an emulsion tower, or other. Be careful not to strip or break the small pilot jet when you try to remove it. It may be necessary to grind the end of a small screwdriver to fit the jet just right. Even after soaking, the jet may still be plugged. Use a small "E" guitar string and push it through the jet. (A wire strand out of a wire brush may work. The wire brush should measure about .013" in diameter.) The smallest jet drill you can get is #80, which has a diameter of .0135". You can use the wire and not enlarge the hole, at least not by much. Yes, some manuals say not to insert any wire jet cleaning tools into the jets. However, Honda and other manufacturers produce them as special tools for the dealer technicians.
Use compressed air with spray cleaner and the wire to clean jets. Spray carb cleaner into the carb passages, and then follow with compressed air. Watch for cleaner to exit from other passage ways and openings, and ensure that those small idle passages are clear. The smallest tubes, passageways, and openings are critical to the operation of the carburetor. EVERY PINHOLE IS IMPORTANT. Make certain that your see and hear air and cleaner pass freely through every opening. Wear goggles and don't get so close that you get carb spray in your eyes.
Sometimes the pins or rods that hold the floats can be gummed. Spray a bit of carb cleaner and let it set awhile. Repeat and try to gently move the float. Eventually, the pin will loosen enough so that you can drive out the pin with a very small punch. If necessary, tap on the punch very gently with the handle of a small screwdriver or similar tool. Penetrating oil also works good to free up gummed float pins and stuck throttle slides. If the slides have a rubber diaphragm on them, spray carb cleaner on a rag and wipe the slide clean. Do not get carb cleaner on the rubber diaphragms. It will ruin them. While you have the Diaphragm out, inspect it for holes. If you have an engine that has good compression and starts well, but just has no power and revs up ever so slowly, check that rubber diaphragm. It may have a hole or tear. The throttle slide will not rise if it is damaged.
When you put the float valve or needle valve back in place, put a drop of light oil on it so it will move freely in its seat and not stick before the gas first starts to fill the bowl.
Don't clean the outside of constant velocity (CV) carbs with spray carb cleaner unless you are sure they are not the rubber diaphragm type. Carb cleaner will ruin the rubber. There is a piston type of CV carburetor, but it's still not a good idea to use the spray because of rubber float bowl gaskets (O'rings).
If you turn on the fuel petcock and gas pours out the overflow tubes, tap lightly on the carb body with a suitable tool. That will vibrate the float valves loose. Same thing if there is dirt holding the valves open. If it doesn't work you need a new float valve & seat. The tips of the float valves can be steel or rubber. Tips with a groove worn in them should be replaced. The float pin springs often become gummed by fuel and cause the pins to stick. Test with your finger. They should be free moving - no resistance. Replace all if you feel any sticking. If they first stuck, but you worked them free, try and use them. They may fail when gasoline gets into the spring again.
Floats control the fuel level in the float bowls. Adjustable tangs on the floats rest on the float valve pins. When level is low, the float lowers and the valve follows. More fuel enters the bowl. Similarly, shutting fuel flow off when it replenishes supply. If the tang is metal, you can adjust the float level by bending the tang up or down. If it is plastic, it is non-adjustable. Float levels are different for each bike and are found in the bikes shop manual. If you don't have the float setting and can't find it anywhere, set it so the fuel level is a bit below the top of the float bowl. Make sure no gas comes out of the float overflow tubes or hoses. The float overflow tube is at the bottom or side of each float bowl. There are many styles of floats: copper, brass, bronze, plastic, urethane, tin, cork, and maybe other materials. Brass and plastic are the most common.
If the rubber ducts that connect the carb and air cleaner housing are hard and dry-rotted, you should replace them. Replace rubber intake manifolds if necessary, too.
On the side of some carbs is another diaphragm that temporarily closes the pilot or slow speed jet air passage when the throttle is closed. This richens the fuel mixture to reduce backfiring when coming to a stop. Check the diaphragm for holes and tears.
At the bottom of some carbs is an accelerator pump to pump extra fuel when the throttle is opened. The pump is attached or connected to one float bowl. Check the pump's diaphragm for holes or tears. A rubber coating called "Plasti-Dip" has been used to fix diaphragms. I have never used it but I hear it works. Get it from NAPA part #765-2527.
Adjustments that you can make from outside the carburetor:
1) Synchronizer screws balance the carburetors for smooth performance and idling. 2) Idle screw (throttle stop screw) adjusts the speed of the idle. 3) The idle fuel/air screw adjusts the idle mixture. This is only at idle and does not effect anything above idle. Another method to adjust it: turn the fuel/air screw in and out until you get the highest idle speed. Then lower the idle speed with the idle screw and do it again until you get the best idle. The air screw can be located in a variety of places on the carb. If you have a 1980 or newer machine, it may have a cover over it to keep you from messing with it. You will have to drill it and then pry it out using the hole you made. It may be illegal for you to do this, depending on where you live.
If you can't get it to idle, or rather the idle stays real high then drops off and dies, check for an air leak. Spray starting fluid, brake cleaner, carb cleaner, etc... on the manifold, carbs, air box, vacuum hoses, and petcock to see if the revs change. If they do, you have a leak. If your valve clearances are too tight, it will also effect the idle.
You can make your air/fuel mixture a bit richer or leaner by moving the carburetor needle clip up or down. Move the clip down a notch to raise the needle, to richen the mixture. Move the clip up to lower the needle, to lean out the mixture. The needle is located in the throttle slide.
(Using An UNLIT Propane Torch For Vacuum Leaks)
Cleaning/rebuilding Suzuki carbs(similar to Kawasaki carbs):
www.thegsresources.com/gs_carbrebuild.htm
Written by MShively
- bl_francis
20 Aug 2012 22:32 #543747
by bl_francis
1987 KZ1000 Police
Thanks for all of the replies everyone. It's great to benefit from the wealth of knowledge here.
The bike has been sitting for more than ten years.
Also I replaced the plugs with some I got at a K. dealer.
Thanks again everyone !
Attachment ImageUploadedByTapatalk1345512746.162593.jpg not found
1987 KZ1000 Police
20 Aug 2012 23:28 - 20 Aug 2012 23:33 #543761
by 650ed
I looked it up on Kawasaki.com and saw that the plugs you bought are the ones specified in the diagram. I guess the cop bikes needed them to suppress noise in their radios. I have never used resistor plugs in my bike and have had no plug problems, so personally, I buy non-resistor plugs. Ed
Last edit: 20 Aug 2012 23:33 by 650ed.
- bl_francis
21 Aug 2012 13:19 - 21 Aug 2012 13:22 #543892
by bl_francis
1987 KZ1000 Police
I am using the stock air filter. It seems pretty old (foam on the verge of crumbly) but very clean.
No police radio so I guess I don't need the resistor. :laugh: When I buy my next plugs I'll get the regular ones.
Thanks everyone.
Taking the carbs apart today. :blink:
Thanks everyone.
1987 KZ1000 Police
Last edit: 21 Aug 2012 13:22 by bl_francis. Reason: missing words
