- Thank you received: 6
Carb Issue????
- badrhino
Cleaned my carbs.
Adjusted Valves
New Spark Plug Wires
Adjusted fuel height/floats
Checked for vacuum leaks
I am having a weird issue. I am still not getting proper firing on cylinder (4). I have tried everything. Switched wires, switched coils, etc. #4 header still not getting as warm as the others.
So I was messing around and pulled the plug off of the #4 carb holder boot and noticed that the bike started running better/ idling faster, and #4 started getting hot like the others.
What does this mean?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- Thank you received: 2098
badrhino wrote: Ok so I have:
Cleaned my carbs.
Adjusted Valves
With normal configuration, does #4 cylinder combust when spraying starter fluid into #4 carb intake?
Any evidence of gasoline on the #4 spark plug when removed after running in non-combusting #4 cylinder?
Visible fat blue spark on #4 plug?
- badrhino
Spark plug does appear to be wet and has alot of carbon build up. I am getting a nice blue spark. I have been switching spark plugs and they are new.
For some reason I don't think I'm getting enough air, hence why the bike seemed to run better when I unplugged the carb boot and introduced a vacuum leak.
Franken Z!
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- badrhino
Franken Z!
- badrhino
Franken Z!
- vintagebiker
If all else fails, JUMP!
- badrhino
Franken Z!
- Motor Head
- Thank you received: 391
