- Thank you received: 680
jet block assembly on 29 smoothbores
- DoctoRot
- 4TheKZ1000
- Visitor
Attachment VM29035-Copy.JPG not found
- Thank you received: 2098
4TheKZ1000 wrote: ...
If the throttle slide seems to be rubbing or binding instead of smoothly operating, check to assure that the screw isn't over-tightened.
- DoctoRot
- 4TheKZ1000
- Visitor
- DoctoRot
4TheKZ1000 wrote: JUST TAKE YOUR TIME, YOU KNOW WHAT YOUR DOING....YOUR GET IT. IM A OLD STEEL WORKER, SO I USED A SMALL DRIFT ON MINE TO KEEP GASKET / BLOCK STRIGHT DURING ASSEMBLY. IT WAS 5 INCHES LONG WITH A 90 DEG BEND ON IT. THE TIP WAS 3/8 INCH LONG WITH A TAPERED TIP, PUT IN HOLE AND SNUGGED IT...WORKED GREAT.
thats the type of smart thinking i was looking for. thanks.
- DoctoRot
I went back and looked at the jet blocks and had realized it was pretty obvious. there is a slot at the top of the jet block so you can stick something down into the hole to make sure it aligns with the pilot circuit. I went back and loosened the jet blocks and re-tightened them holding a needle tool in the hole to align them. I'm glad i did, as two of the blocks were not fully aligned, i could feel the needle slide in more once i loosened the blocks.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
DoctoRot wrote: Ive been meaning to post this info up in case some one is looking for it in the future.
What is that you are using to align the jet block? Mighty young looking hands...you a doctor or something?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
And if screwed in too tightly, will distort fitment enough to prevent proper clearance for operation of the throttle slide.
