- Thank you received: 445
Was told that these were 28mm Smoothbore Carbs
- gd4now
- Denco where did you go?
27 Jul 2012 21:24 #539109
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Was told that these were 28mm Smoothbore Carbs
Sorry but I just do not see the pump on the pic he posted what am I missing?
1977 KZ650 B1
- dragtostreet
- Thank you received: 1
27 Jul 2012 23:33 #539137
by dragtostreet
Replied by dragtostreet on topic Was told that these were 28mm Smoothbore Carbs
I can assure everyone there is no accelerator pump
- baldy110
- Thank you received: 512
27 Jul 2012 23:54 #539144
by baldy110
Replied by baldy110 on topic Was told that these were 28mm Smoothbore Carbs
Geez guys you don't have to get nasty. I have worked on a few 29's and none of them had pumps or the side drain plugs. If you look close at the pic I see what I thought was the pump rod boss, I guess I was wrong on this you can all let it go now.
- wireman
- Thank you received: 299
28 Jul 2012 00:01 #539146
by wireman
Replied by wireman on topic Was told that these were 28mm Smoothbore Carbs
Relax man. :laugh:
Theres lots of differant variations of smoothbores out there,when I was young/sneaky little bastard I would run the float bowls with the angled screws on 29s just because most people thought they were 26s. :evil: :woohoo:
And yes acc pump is another option on the 29s
- wireman
28 Jul 2012 00:02 #539148
by wireman
That reminds me,wiredgeorge still owes me a steak over our bet on those float bowls from way back when! :woohoo:
- Thank you received: 2098
28 Jul 2012 09:30 #539205
by Patton
Replied by Patton on topic Was told that these were 28mm Smoothbore Carbs
Per info from Z1 Enterprises:
Note: some very early sets of 29mm smoothbore carbs have a float bowl with a small drain screw angled to the side.
Click this link and scroll down to the discussion about smoothbores.
www.z1enterprises.com/Z1CarbGuide.aspx
28 Jul 2012 09:39 #539206
by Patton
As known, one caution when running smoothbores is being extra careful to assure perfect float valve function, because excess gasoline in a float bowl may rise into the carb throat and find its way into the crankcase.
Yes, this subject came up in a thread about whether some other float bowl could be fitted to a smoothbore carb in order to provide an overflow function.wireman wrote: That reminds me,wiredgeorge still owes me a steak over our bet on those float bowls from way back when! :woohoo:
