- Thank you received: 1
Was told that these were 28mm Smoothbore Carbs
- dragtostreet
- wireman
- Thank you received: 299
- gd4now
- Denco where did you go?
- Thank you received: 445
Should be an ID like this
29
A(some other number either 2 or 7 or 12)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- peter1958
- Banned
- Thank you received: 198
- dragtostreet
- baldy110
- Thank you received: 512
- wireman
- dragtostreet
- 4TheKZ1000
- Visitor
Attachment th_2012-07-27.jpg not found
- 4TheKZ1000
- Visitor
- gd4now
1977 KZ650 B1
- wireman
Yes Ive had 29s with pumps on them,its just an accesary part for them.4TheKZ1000 wrote: Those are not 29's look at the bottom of the float bowl those have a round drain plug mounted on the side, 29's have a 17mm hex drain plug on the bottom. Those also have an acclerator pump, 29's did not have an accelrator pump. I would say you have a set of VM26's or VM28's.
