- Thank you received: 4
Stock J carbs on an 1135 will not idle
- kawasaki mike
- kawasaki mike
24 Jul 2012 13:39 #538205
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Stock J carbs on an 1135 will not idle
Do you think you might have put the cams in and missed the set up by one tooth? It happens and will cause all kinds of tuning problems.
- daskraut
24 Jul 2012 14:56 #538232
by daskraut
When in doubt, GAS IT!!
Replied by daskraut on topic Stock J carbs on an 1135 will not idle
I tore into the valves sunday night and checked my T 1-4 mark vs my intake and exhaust arrows(both at head surface, and then checked my 44 pins also, it all looks proper....
- baldy110
- Thank you received: 512
24 Jul 2012 17:36 #538296
by baldy110
Replied by baldy110 on topic Stock J carbs on an 1135 will not idle
I have pretty much the same setup as yours with the exception of a mild port job. I dumped a bunch of time and money into the BS34's trying to get them to work and I had the same symptoms you do. I eventually shelved the BS34's and bought Wired George's "VM30" performance carbs. I am currently dialing them in and am almost there. All my issues I had with the BS34's are gone with these. Just a thought. I have put the BS34 carbs on alot of bikes and got them to work pretty well but for whatever reason I could never get them to work with my current setup.
The following user(s) said Thank You: daskraut
- lushbaugh
- everybodys a pro......
- Thank you received: 35
24 Jul 2012 19:31 #538333
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Stock J carbs on an 1135 will not idle
Refer to first post "cvcarbs are the devil" tape off some of the surface area of the pods and see what happens for shits and giggles. About a third. And if not upgrade carbs cause realistically cvs are of no performance.value
- daskraut
24 Jul 2012 23:23 #538384
by daskraut
Baldy 110, I do in fact have a mild port job, the head is a Cavanagh stage 1. what year is your bike and what cams?
- baldy110
25 Jul 2012 00:52 - 25 Jul 2012 00:58 #538422
by baldy110
82 GPZ1100 with 1135cc big bore kit 10.5-1 compression, stock cams and stage 1 porting by Pitstop performance. I am running pods with a kerker KR pipe with the race baffle off an 82 KZ1000S1. I spent nearly 6 months and about $300.00 in jetting and "jet kits" for the BS34's and was never able to get them dialed in. I even bought another set of BS34's thinking the set I had was somehow defective. I must have taken the carbs on and off and had themn apart over 50 times trying to figure why they wouldn't work. Live and learn I guess.
Here is the link to my build.
www.kzrider.com/forum/11-projects/480871-elr-clone#480871
Last edit: 25 Jul 2012 00:58 by baldy110.
- daskraut
25 Jul 2012 01:48 #538436
by daskraut
did you have the same idle problem?
- Motor Head
- Thank you received: 391
25 Jul 2012 02:05 #538437
by Motor Head
Replied by Motor Head on topic Stock J carbs on an 1135 will not idle
Just wondering if you are using the Non Bleed type of pilot jet or the bleed type? Are the pilot jet plugs in place, and what sort of setting are you at with the mixture screws?
- daskraut
25 Jul 2012 02:39 #538443
by daskraut
bleed type??, not following you. I have the plugs in that follow the pilot jets.
- Motor Head
25 Jul 2012 09:46 - 25 Jul 2012 09:50 #538477
by Motor Head
Have a look at this thread on Pilot Jets for the CV carb. This where I found clear pictures for each type. The small holes are an Emulsion tube, which does cause an effect on the slow circuit. It may be small though. Just wondering which you have, as I believe the Non- Bleed is the Stock type.
kzrider.com/forum/3-carburetor/180091-wh...t-for-mikuni-cv-carb
Last edit: 25 Jul 2012 09:50 by Motor Head.
- baldy110
25 Jul 2012 12:32 - 25 Jul 2012 12:33 #538506
by baldy110
Yes, I had the same hanging idle and for the bleed jets it doesn't matter what type you use. I tried both and they never made a difference. I really think the intake porting screws up the vacumn signal to the CV carbs not alowing the idle circuit to operate correctly.
As I mentioned earlier I have used BS34's in a lot of different bikes with success but this was the first time I used them on an engine with intake porting.
If you do happen to get yours to work let me know and how you did it.
Last edit: 25 Jul 2012 12:33 by baldy110.
- daskraut
25 Jul 2012 23:34 #538689
by daskraut
Baldy, when you can, give me more details on your current carb set up and any advantages it has over other carbs (CRs, flat slides etc.)
