What causes popping in one cylinder.
  • KZCool
  • KZCool's Avatar Topic Author
14 May 2012 13:15
#522294
I have a 76 Kz50B. Got my bike running and everything is cleaned out of the carbs. Timing is dead on, and I'm pretty sure they are synced well. Was are the major causes of popping. I have just the headppes on, and theres a leak in the exhaust gasket of the same cylinder. Could that be it?
1976 KZ750 hardtail
  • bountyhunter
  • bountyhunter's Avatar
Re: What causes popping in one cylinder.
14 May 2012 15:31
#522311
KZCool wrote: I have a 76 Kz50B. Got my bike running and everything is cleaned out of the carbs. Timing is dead on, and I'm pretty sure they are synced well. Was are the major causes of popping. I have just the headppes on, and theres a leak in the exhaust gasket of the same cylinder. Could that be it?
Yes, leaky exhaust gasket will make the popping sound louder. Popping on decel is caused by a lean condition in pilots or also vacuum leak, timing off. I recommend #50 pilots.
  • KZCool
14 May 2012 17:26
#522331
I've already increased the jets since I have a K&N filter, but I couldnt tell you what size. And its just at idle when its warmed up that it pops. It's not that I can hear the pop from the gasket leak, I just thought maybe its somehow messing with the air flow or mixture or something. I'll get a new gasket anyway.
1976 KZ750 hardtail
14 May 2012 18:02
#522337
Do you plan to install an exhaust system? Running with just header pipes and no collector or can is going to make tuning difficult not to mention reduce the engine's power because of the absence of Bernoulli effect (scavenging) and the gross reduction of back pressure. Ed
  • Old Man Rock
  • Old Man Rock's Avatar
14 May 2012 20:03 - 14 May 2012 20:06
#522380
As mentioned, a single carb popping is a LEAN condition due to more air then gas whether it's from leaky manifold, miss adjusted pilot air screw, screwed up carb circuits etc...
"I'm pretty sure they are synced well"... :huh:
If you took those carbs apart to clean, chances are they are not sync'd...
Ah hell with it, I'm Pretty sure they wont be... :pinch:
Wild guess here, when was the last time you sync'd them...?
Before going crazy on the carbs... Confirm your sync, you might be surprised how far off they can and will be otherwise you'll be chasing this all over the place.... Then go after your proper jetting... It's a trial and error scenario to get dialed in especially w/out the right tools (Vacuum Gauges / Morgan/ Color Tune etc...)...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 14 May 2012 20:06 by Old Man Rock.
  • bountyhunter
15 May 2012 03:01 - 15 May 2012 03:05
#522464
KZCool wrote: I've already increased the jets since I have a K&N filter, but I couldnt tell you what size. And its just at idle when its warmed up that it pops. It's not that I can hear the pop from the gasket leak, I just thought maybe its somehow messing with the air flow or mixture or something. I'll get a new gasket anyway.
Check fuel levels with clear tube and check synchronization. Still think it's lean pilot.
EDIT TO ADD:
Is that a straight pipe in the picture? That will run REALLY lean.
Last edit: 15 May 2012 03:05 by bountyhunter.
  • jeffasaki
  • jeffasaki's Avatar
15 May 2012 03:18
#522468
all depends on the pipe the carbs and the way that you ride it
if you have a good scavange pipe and small carbs
and run it hot
then flood the pipe and shut the carbs down
the pipe will scavange unburnt fuel and flame and cause a loud pop
what carbs and what pipe you running?
How are you riding it?
also you are golden until a cop says thats too loud
which wont happen any time soon
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • KZCool
15 May 2012 16:48
#522546
As for my pipes, it is a straight pipe, but i put a baffle in it to increase back pressure. I have a custom highrise system in mind, but gotta get the seat done first. Nothin like riding 50 miles on metal. I synced them right after i took them aprt and everything. I have vacuum gauges, but I 'll try it again. Fuel level is good too, checked that wen they were off.
"also you are golden until a cop says thats too loud" lol that'll never happen in my town, not with all the rednecks and thier stright pipe trucks driving around me. I ride pretty low key, just crusin around with the ocassional 100MPH rush ;). Last time I checked my plug it was a little rich, and I tried the piolet jet and it didnt help.
1976 KZ750 hardtail
  • KZCool
16 May 2012 07:35
#522647
I pulled the plugs yesterday after a 45 minute ride on the hiway and leting it idle a bit at home and both plugs looked about the same, a very light brown maybe a tad lean. Only difference was the one that pops had black soot on the ring of the thread bottum and the threads had oil on them. Side note- maybe bad rings?
anyway, the bike seemed a little reluctant to idle when I pulled into the drive, and I've always had problems with overheating, so I think that was the case there.
1976 KZ750 hardtail
  • KZCool
17 May 2012 19:09
#522975
"bump"
1976 KZ750 hardtail
  • bountyhunter
17 May 2012 19:27 - 17 May 2012 19:28
#522976
You running the right plugs? The twins use the B6ES plug.
These things are notorious for bad valve guide seals and then the oil runs down onto the plugs after you turn the engine off.
Guess how I know.......
Maybe bad rings, but bad seals are likely too.
Last edit: 17 May 2012 19:28 by bountyhunter.
  • KZCool
20 May 2012 19:33
#523616
Thanks for the heads up. I'll have to take the head off to replace those wont I?
1976 KZ750 hardtail
