What causes popping in one cylinder.
  • bountyhunter
  • bountyhunter's Avatar
Re: What causes popping in one cylinder.
21 May 2012 01:54 - 21 May 2012 01:55
#523751
KZCool wrote: Thanks for the heads up. I'll have to take the head off to replace those wont I?
I would, but it's possible to change them with head on. Somebody says you feed cotton twine in the spark plug holes to "fill" the combustion area and gently raise piston to TDC... that holds the valve up while you take the spring off and change the seal. I never tried it.
Last edit: 21 May 2012 01:55 by bountyhunter.
  • Motor Head
  • Motor Head's Avatar
21 May 2012 10:11
#523793
KZCool wrote: "bump"
Have you checked your valve clearances?
Ohm checked your coils, and plug wires/caps?
Does this bike still have points and condenser? If so hows the condition, setting of the contact points and timing? You could have a condenser crapping out.
  • KZCool
  • KZCool's Avatar Topic Author
21 May 2012 13:09
#523826
Checked the vale clearances and adjusted last season, Checked the coil and its fine cool, but I have yet to check it when its warm. Plugs are new, and so are caps. How do you check wire resistance and any clue what it should be? As for ignition, all new dyna s system wit the usual coil mod for power stright from the battery.
1976 KZ750 hardtail
  • KZCool
21 May 2012 13:12
#523827
It's not a loud constant popping, just every third or fourth cycle at idle and just kind of anoying, can be kinda loud sometimes. I'm picky like that.
1976 KZ750 hardtail
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
21 May 2012 13:46
#523833
Did you replace the exhaust gasket?
  • KZCool
22 May 2012 08:24
#523978
THey're on thier way. Just ordered them from Z1 the other day.
1976 KZ750 hardtail
