New jets on KZ750?
- rhb629
I recently picked up a 1981 KZ750E (the 4, not the twin) as a project. One of the things I'm setting out to do is some carb work. I've done some reading on here, but wanted to get a second opinion before I get to work.
The air box on the bike is broken. The previous owner intended putting POD filters in it, although I realize this will need some jetting. A #70 primary main and #140 secondary seems popular with this configuration? Do I need to adjust the pilot jet too, and are the pods 54mm?
P.O. also had a Vance & Hines 4-1 exhaust installed and he said it was running lean because of it. If I do a #70 and #140 on the jets with PODs, will this be adequate for the exhaust too?
I appreciate the help.
1978 Kawasaki KZ650B
1981 Kawasaki KZ750-E2 ( kzrider.com/forum/11-projects/506846-1981-kz750-e2-project )
1973 Honda CB350G
1981 Honda CM400C (sold)
1986 Honda CMX250 (sold)
- adrenalinrider
1st Bike 1981 Kz550A Pods,Mac 4 into 1, Stage 3 Dynojet kit
- Thank you received: 1656
- JR
- Thank you received: 448
rhb629 wrote: Hello, this is my first post in the forum.
Assuming you have Keihin CV34 carbs like me
I have a Mac 4 into 1 exhaust on mine, a 1980 750/4 and when I had K&N pods I had the 70 and 140 jets. You should not have to do anything with the pilots. I dont think different pilot jet sizes are available anyway. I cant remember how many turns out I had the air screws. Either 2 or 3 turns out. Having the correct fuel level in the carb bowls is really really important for either lean or rich running. If you are going to do anything with the carbs measure and I mean measure not eyeball the fuel level and adjust to spec. Hsrd to imagine a different brand of exhaust would make that big a difference. Besides. Remember. The previous owner always lies.
Finally. I bought an air box in a boneyard and I prefer the low end performance. I put all jets to stock except the seconday main which is 130... I think
- rhb629
Are the PODs that much better? I like how they look and it seems like if I put the air box on instead I'd have to take the carbs off anyway.
JR, why did you keep the secondary at 130 with the box?
1973 Honda CB350G
- JR
You might find an airbox top screw cover on ebay. You can get the springs and new supple airbox hoses from Z1enterprises.com
When I bought the bike it had K&N pods which do look cool and I believe I got the jetting correct and the bike ran well. However I decided to go for a more stock look and bought an airbox on impulse at a recyclers one day. I like the look and I prefer how it now runs. Pods may be better at high speeds. I kept the secondary main at 130 to allow for the Mac 4 -> 1 exhaust
- rhb629
If I end up doing PODs, does anyone know the tube diameter? Looks like 54mm, but some sources list my bike ('81 KZ750-E 4 cycl) as 42mm.
At work right now so I can't go out and measure it
1973 Honda CB350G
- JR
Here's an old pic of 2 of my old my old K&N pods with a ruler. I can dig them out of the shed in the morning when the snow has stopped and take a more accurate measurement if you need. If you do go with pods, have fun. Dont be discouraged by the naysayers here, but keep the airbox in case you ever want to go back.
- rhb629
I've been tearing the bike down and have easy access to it right now:
1973 Honda CB350G
- rhb629
I noticed the P.O. took the overflow tubes off the carbs, probably when the airbox was removed. Do I necessarily need these, and if I do, where should they flow to if there is no airbox?
1973 Honda CB350G
- Thank you received: 2098
rhb629 wrote: I've got some of my parts in and will doing some work over the next couple of weeks. One question though:
Would route overflow hoses to exit underneath the bike where fuel discharge won't get on the engine.
- apbling
- Thank you received: 12
Also, if you are going to clean the carbs, make SURE you get all those tiny little pilot/transition holes and passages clean. Mine ran somewhat crappy until I got these squeeky clean. Also, be very very gentle with your diaphragms. They are fragile (I never even made a dirty look at mine out of fear they would tear) and are expensive and not that easiest to find.
