Drouin supercharger
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
Re: Drouin supercharger
28 Dec 2011 22:09 - 28 Dec 2011 22:15
#495043
DAMNIT!!! ALL THESE PICTURES ARE JUST MAKING ME SAD SINCE ILL NEVER FIND ONE :D seriously guys, They look COOL!! wouldnt a standard starter motor work if i did the belt drive from The clutch instead of the crank on the left side? I sent Zed1015 a message since it looks like he deals with these superchargers quite a bit but now that i see how hard it is to find them, i dont think hes gonna want to sell me one :( Ahhh well, it was a fun idea while it lasted but if i ever do come across a supercharger, there is gonna be one huge thread in the projects forum.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 28 Dec 2011 22:15 by Kitten Tooth. Reason: wrong wording
  • Kitten Tooth
28 Dec 2011 22:12
#495045
z1kzonly wrote: You would go crazy trying to get one of them to run on the street!
Unless you had it alcohol injected. And a dragbike outboard starter cart following you.
I have been trying to buy this one for 5 years. I took these pictures 5-6 years ago. This guy never got it running long enough to ride it.
Look at the rust on the header.
He wants $2,000 for the set up, not including the bike. He said he would let it sit till he dies, before giving it away. He is in his late 60's.
Why didn't he ever get it running properly? I had another post on here awhile back about making an Alchohol KZ1000. I never knew that a supercharger would fit right in with that equation.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
28 Dec 2011 22:15
#495047
and im sure ill have more fun flying around town with my dad on 2 mildly stock bikes rather than one with a huge ass supercharger on it that my dad cant keep up with XD Oh btw, it rocks having two identical motorcycles in the garage. My dads got an 81' LTD1000 as well.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • jeffasaki
  • jeffasaki's Avatar
28 Dec 2011 22:58
#495062
ill pay the 2 grand for the supercharer setup
ill buy the whole rig get it running right and let the old guy take it for a ride
how does that sound?
PM me
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • Tony
  • Tony's Avatar
29 Dec 2011 01:28
#495086
t
  • Kitten Tooth
29 Dec 2011 04:25
#495101
NNNNNNOOOOOOOOOOO I WANT IT!!!! lol i aint got no money :D go ahead dude :)
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
29 Dec 2011 04:26
#495102
and i dont think that setup would work on a J motor would it?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Mookachacka
  • Mookachacka's Avatar
Re: Chanel Bags
29 Dec 2011 09:15
#495106
wireman wrote: Tou can pick up a good used complete turbo for $1000-$1500,just have to do some looking is all.
infinately tuneable,will smoke a carbed motor without breaking a sweat! :woohoo:
I saw a used turbo that was marked "Blake" on the pipe going from the turbo it self, seller said it would probably fit kz1000 and gs1000/gs1100, 600$ he wanted.
  • Kitten Tooth
Re: Chanel Bags
29 Dec 2011 11:29
#495128
A turbo and a supercharger both basically do the same thing right? The supercharger is just more efficient. At least that what my shop teacher says. The turbo just crams air into the motor just like a supercharger only with recycled exhaust right?
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Re: Chanel Bags
29 Dec 2011 12:07 - 29 Dec 2011 12:10
#495141
Kitten Tooth wrote: A turbo and a supercharger both basically do the same thing right? The supercharger is just more efficient. At least that what my shop teacher says. The turbo just crams air into the motor just like a supercharger only with recycled exhaust right?
Both turbo and supercharger force additional fuel mixture into the cylinder.
Turbo -- Exhaust spins the Turbo without using engine power.
Fresh air is used in the fuel mixture. Exhaust output isn't part of the fuel mixture.
Engine must be spinning for exhaust pressure to spin the turbo. That's the reason for turbo "lag" from low rpm, which occurs until the engine gets going fast enough to produce sufficient exhaust pressure to spin the turbo. Lower compression pistons are fitted, which allows larger combustion chambers for the turbo to force-feed. The initial low compression also contributes to the lag time off idle. And when the exhaust pressure gets sufficient to spin the turbo, then the magic happens.
Supercharger -- Uses some engine power to force-feed additional fuel mixture into the cylinder.
It performs immediately off idle, and without lag. Instant magic.
At least that's my simplistic understanding. Others will have better and more competent explanations.
Good Fortune! :)
Last edit: 29 Dec 2011 12:10 by Patton.
  • z1kzonly
  • z1kzonly's Avatar
Re: Chanel Bags
29 Dec 2011 13:14
#495146
Could always put a shot of Nitro in your alcohol drink
Syracuse NY
  • steell
  • steell's Avatar
Re: Chanel Bags
29 Dec 2011 14:54
#495151
Doesn't Jeff at Z! have a supercharged KZ?
