Help with zx1100 a2 inj
- chewy
21 Dec 2011 08:10 #494086
by chewy
Help with zx1100 a2 inj was created by chewy
Hi can anyone help me have stripped and rebuilt engine on my gpz 1100 a2 (84) have checked timing perfect real good compression all 125+psi and have good spark and get damp plugs but wont start not even try any ideas ?
- 0Z.Z1R Mk2
- Thank you received: 31
21 Dec 2011 08:21 #494087
by 0Z.Z1R Mk2
Replied by 0Z.Z1R Mk2 on topic Help with zx1100 a2 inj
Does the fuel pump make a noise when you turn the ignition on?
The following user(s) said Thank You: chewy
- chewy
21 Dec 2011 08:24 #494088
by chewy
Replied by chewy on topic Help with zx1100 a2 inj
hi yes the pumps fine
- 0Z.Z1R Mk2
21 Dec 2011 08:31 #494089
by 0Z.Z1R Mk2
I take it you've had the bike running previous to the rebuild?
- chewy
21 Dec 2011 08:33 #494090
by chewy
yeah was running fine just replaced head gasket as oil seeping out by no. 1 cylinder that all ran fine uptill then
- 0Z.Z1R Mk2
21 Dec 2011 08:45 #494091
by 0Z.Z1R Mk2
Chewy,there's nothing I can think of at the moment that's stopping it from starting...other than a flat battery or bad wire connection somewhere perhaps.
Someone else may be able to help you out....welcome to the forum BTW.
- LarryC
21 Dec 2011 09:46 - 21 Dec 2011 09:47 #494101
by LarryC
Larry C.
Replied by LarryC on topic Help with zx1100 a2 inj
When I see this happen, it's generally the ignition coil wiring is reversed. Check that first!
Other than that check this:
Throttle plates not jammed open too far.
Vacuum line is connected to pressure regulator
Cam timing.
Cam timing.
Larry C.
Last edit: 21 Dec 2011 09:47 by LarryC.
- DFIGPZ
- Thank you received: 122
- chewy
21 Dec 2011 22:57 #494244
by chewy
+1 means ?
- LarryC
22 Dec 2011 00:05 - 22 Dec 2011 00:27 #494249
by LarryC
Last edit: 22 Dec 2011 00:27 by LarryC.
- Mookachacka
- Thank you received: 4
22 Dec 2011 05:25 #494286
by Mookachacka
It means that one agrees with the previous poster, in this case Larry C.
Replied by Mookachacka on topic Help with zx1100 a2 inj
chewy wrote: +1 means ?
- baldy110
- Thank you received: 512
22 Dec 2011 14:25 #494337
by baldy110
Replied by baldy110 on topic Help with zx1100 a2 inj
Have you checked if the plugs are actualy sparking?
