78 kz 650 4 into 2 carb size
- 78oldschoolchop
19 Dec 2011 19:50
hello i have a 78 kz 650 that i have been running around for some time now, and i have been wanting to change things up a bit. i have a 1968 triumph 650 that i run with one 34 instead of 2 32's. and have been wanting to clean the look of my kz up, is there a formula for reducing the number of carbs to figure out what size i need or is it trial and error? or if anyone knows of a good setup that would be good. but i really want to understand the math behind it.
- Nebr_Rex
Re: 78 kz 650 4 into 2 carb size
19 Dec 2011 23:26
Won't work,2 carbs to 4 cylinders or 1 for all 4,look at your firing order.
If it does run it'll run like shit.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- 78oldschoolchop
20 Dec 2011 00:07
can you elaborate at all because im not sure i understand the fireing order all cars run off of one carb? just want to know the reason?
- DoubleDub
20 Dec 2011 00:29
It's doable - the turbo 1000's used to run on a single carb. Not sure it's worth it, though. This has been discussed in the past, I believe.
- Nebr_Rex
20 Dec 2011 00:58
1342
With 2 carbs you will have 2 pulses then nothing for 2 events.
With 1 Carb even fuel distribution will be a problem.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- DoubleDub
20 Dec 2011 01:07Nebr_Rex wrote: 1342
Agreed, but as I said, it's doable with one. And as I said, I don't think it's likely worth it.
- ramtough_63
20 Dec 2011 01:22
running a single 42?? Kehin on my GL1200 I love the people who say you cant do that!
Good tourque smooth power.
Firing order doesn't matter gas is atomized into a vapor that fills the runners of the intake just my .02
I will dig some better pics up when I have time.
used a branch (harley fast guys)intake with PVC runners plumbed to factory intake done it in abour 2 hours.
Have 2 years maybe and 5000 miles without any serious problems (fuel pump went out experimented with corvette fuel pump with regulater settled on what I believe is a yamaha fuel pump free from the shop)
Attachment 30383_2011-12-19.jpg not found
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- wireman
20 Dec 2011 02:01
its just a matter of plumbing it,youre only feeding 2 cylinders at any one time anyway.
- wireman
20 Dec 2011 02:05you can run a 2brrl or a 4brrl or 3 2s or 2 4s on a v8,why cant you run 1 carb on a 4cyl bike motor?Nebr_Rex wrote: 1342
ive run many turbo charged bikes over the years with one big carb with no problem
- jonnybravo
- Banned
20 Dec 2011 09:13
a kz1300 runs 6 cyl off 3 carbs so why not ???
- JR
20 Dec 2011 10:25
One of the members here put a single carb on a 650. It was several years ago. The carb was from automobile. Perhaps an SU carb ? Not sure. He made a manifold from inch and a half or two inch copper tubing. He did say it was relatively easy and not much tuning required. I'm thinking it may have been The Milkman or maybe Biquetoast and also that it was on the old site.
- Godfrey
