78 kz 650 4 into 2 carb size
- 78oldschoolchop
Re: 78 kz 650 4 into 2 carb size
21 Dec 2011 19:12 - 21 Dec 2011 19:16
Does any more feel that one 34mm mikuni flat slide is too small. I would love to know the math here. I feel there has to be a calcutiom that can be made. If one 42 can run a Turbo bike I feel this is with in the right range.. please tell me if I'm way off.
Last edit: 21 Dec 2011 19:16 by 78oldschoolchop.
- ramtough_63
21 Dec 2011 20:26
I used the calculation of the big cc Harleys run carbs in the 40"s so it must work on a 1200
with that said I wasnt entirely right. intake runner length and location affect the actual cfm IE High rise intakes on a v8 fortunately my runners were very long on the goldwing
I am sure there is a calculation when the built my Chevelle motor they did some kind of water test to figure out the overall volume and the calculation came our to 628 cfm carbuteyor and Holley just happen to have a 630 pro series available.
I am sure the calculation is the same look on the drag race forums
hope this helps
hope this helps
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- ramtough_63
21 Dec 2011 20:32
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
The following user(s) said Thank You: kacivic
- DoubleDub
21 Dec 2011 20:34 - 21 Dec 2011 20:35
I believe you want to match it to your max cfm (air flow) through the engine. Otherwise it will restrict the engine. This depends greatly on the rpm range of the engine which means that the 650 will likely run a much larger carb than a Harley of a similar size would. I think you'll be looking somewhere in the 38+ mm range to do it right.
disclaimer: I'm no expert.
Last edit: 21 Dec 2011 20:35 by DoubleDub.
- 78oldschoolchop
- damarble
02 Aug 2012 13:51
Good job making it work. I've seen widely varying reports on how well these conversions work.
I'm considering doing a single or duals on a 4cyl Yamaha Venture 1200. I'm thinking a single 42 like ramtough did or a pair of 36s maybe?
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
