- Thank you received: 31
Tank leak......
- 0Z.Z1R Mk2
Fitted mine dry and I'm having leak problems....any recommendations on what to use?
- steve.w
- 0Z.Z1R Mk2
- Thank you received: 2098
Actually shouldn't need anything on the o'ring except perhaps a light coating of silicone lube -- not sealant.
Silicone sealant doesn't play nice with gasoline, at least not for a long term relationship.
Just my 2¢
- RonKZ650
- Thank you received: 241
- Motor Head
- Thank you received: 391
Be very careful here as fuel is really flammable.
See up in Smoke
- Thank you received: 1656
- 0Z.Z1R Mk2
Motor Head wrote: See up in Smoke
The Cheech and Chong movie?
martin_csr wrote: Are you installing a new gasket? What's the condition of the mating surfaces on the tank & sender?
Yes a new aftermarket gasket...not oring,will check the surfaces before refitting.
Thanks all.
- Motor Head
- JR
- Thank you received: 449
martin_csr wrote: I would probably hit the surfaces w some steel wool or brass wool or something. Or give 'em a light wet sanding.
If the aftermarket gasket is the problem, here's an oem part. Kawasaki fuel gauge gasket 78-05 nos 11009-1037
+1
When I bought my bike 8 years ago the PO had just had the tank repainted and there was a small leak where the rubber - in my case O ring - was pressed against the tank. Of course the paint had dissolved and the gasket was no longer sealing. bit of steel wool and fine emory paper removed the remaining paint and allowed the O ring to seal against the metal.
- 0Z.Z1R Mk2
I'm now thinking fuel is coming from the plastic unit in the center from which the wire is attached.
Any thoughts on this???
