Tank leak......
30 Nov 2011 06:59 - 30 Nov 2011 07:00 #490805 by 0Z.Z1R Mk2
Tank leak...... was created by 0Z.Z1R Mk2
Does the rubber gasket between the tank and the fuel sender require some sort of sealant?
Fitted mine dry and I'm having leak problems....any recommendations on what to use?
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
Last edit: 30 Nov 2011 07:00 by 0Z.Z1R Mk2.
30 Nov 2011 11:53 #490821 by steve.w
Replied by steve.w on topic Tank leak......
silicone will do the job ;)
30 Nov 2011 23:03 #490891 by 0Z.Z1R Mk2
Replied by 0Z.Z1R Mk2 on topic Tank leak......
Thanks turbanana...will use some Permatex #3. ;)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
30 Nov 2011 23:23 - 30 Nov 2011 23:25 #490894 by Patton
Replied by Patton on topic Tank leak......
Would consider #2 instead because it's supposedly "fuel resistant" whereas the #3 doesn't specify as being fuel resistant.
Actually shouldn't need anything on the o'ring except perhaps a light coating of silicone lube -- not sealant.
Silicone sealant doesn't play nice with gasoline, at least not for a long term relationship.
Just my 2¢
Good Fortune! :)
Last edit: 30 Nov 2011 23:25 by Patton.
30 Nov 2011 23:39 - 30 Nov 2011 23:42 #490896 by RonKZ650
Replied by RonKZ650 on topic Tank leak......
yamabond #4 works great for this. THat oring is a pain in the ass. i always seal it just so I don't have to fight leaks. Edit- I was refering to the stupid oring on the petcock to the tank, the fuel sender I'm not familier with. A gasket should never normally need sealer of any kind.
Last edit: 30 Nov 2011 23:42 by RonKZ650.
  • Motor Head
30 Nov 2011 23:51 #490900 by Motor Head
Replied by Motor Head on topic Tank leak......
Just ask Clutch what he thinks about Permatex and sealing a fuel fitting/ gasket!! :sick:
Be very careful here as fuel is really flammable.
See up in Smoke :P
01 Dec 2011 02:04 - 18 Feb 2013 18:34 #490924 by martin_csr
Replied by martin_csr on topic -
Last edit: 18 Feb 2013 18:34 by martin_csr.
01 Dec 2011 04:27 - 01 Dec 2011 05:42 #490931 by 0Z.Z1R Mk2
Motor Head wrote: See up in Smoke :P
The Cheech and Chong movie?
martin_csr wrote: Are you installing a new gasket? What's the condition of the mating surfaces on the tank & sender?
Yes a new aftermarket gasket...not oring,will check the surfaces before refitting.
Thanks all. B)
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
Last edit: 01 Dec 2011 05:42 by 0Z.Z1R Mk2.
  • Motor Head
01 Dec 2011 08:52 #490941 by Motor Head
The Stag Jointing Paste, from your Gas Fitter or Plumbing Stockist will hold up to Petrol. Even here in the US with the Ethanol, it holds up. But if the Gasket is new, and everything is proper, then nothing should be needed.
01 Dec 2011 10:24 - 18 Feb 2013 18:35 #490951 by martin_csr
Last edit: 18 Feb 2013 18:35 by martin_csr.
02 Dec 2011 00:35 #491050 by JR
Replied by JR on topic Tank leak......
martin_csr wrote: I would probably hit the surfaces w some steel wool or brass wool or something. Or give 'em a light wet sanding.
If the aftermarket gasket is the problem, here's an oem part. Kawasaki fuel gauge gasket 78-05 nos 11009-1037
+1
When I bought my bike 8 years ago the PO had just had the tank repainted and there was a small leak where the rubber - in my case O ring - was pressed against the tank. Of course the paint had dissolved and the gasket was no longer sealing. bit of steel wool and fine emory paper removed the remaining paint and allowed the O ring to seal against the metal.
03 Dec 2011 05:46 #491226 by 0Z.Z1R Mk2
I have removed the tank 2 or 3 times and tried different methods to stop the leak from the fuel sender unit.. :evil:
I'm now thinking fuel is coming from the plastic unit in the center from which the wire is attached.
Any thoughts on this???
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
