- Thank you received: 2098
dies without choke, but the carbs are clean!
If the kit included new jet needles, perhaps they have an incorrect taper.abrambila wrote: 1978 KZ650 D1... rebuilt the carbs with the kit from z1....
Could reinstall the old jet needles, and test run for effect.
- abrambila
any chance it could be a petcock issue? i did notice that it works slightly better running on the on position rather than the prime position (when the vacuum is working). This seems odd to me as the idea is that prime just dumps gas. generally, the petcock does work. prime makes gas pour out, on and off stop the flow.
1978 KZ650 D1
- Motor Head
- Thank you received: 391
- abrambila
1978 KZ650 D1
- Motor Head
Are they #5CN15, #5CL10, or #5CL16? All three are listed for your bike. Does your Carbs have the accelerator pump?
- abrambila
no accelerator pump on the carbs. The needles I put in were the ones in the z1 rebuild kit. i'm not sure what the numbers were.
1978 KZ650 D1
- BlackEyeCafe
Anything else you recommend?
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
- zed1015
- Thank you received: 1569
BlackEyeCafe wrote: Patton - if i have no air or carb cleaner coming out the #6 orifice, what can i do to remedy the situation? Tried compressed air air at 125psi. Tried soaking in carb cleaner.
This is a very old thread and you won't get a reply from Patton unless you are a medium as the sadly passed a while back.
Probably best to start a new thread and explain your issues there for a better response.
- BlackEyeCafe
1977 KZ650 C
