- Thank you received: 17
carbon fouled plugs
- gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
- Thank you received: 2098
gengomerpyle wrote: last night i took my bike out. it ran like crap so i went and picked up some new plugs. i gapped them at .040 like kawasaki told me and it still ran like crap. i only ran it for about 5 minutes on the new plugs. i looked at the manual last night and it says to gap between .028 and .032. so this morning i pulled the plugs to re-gap them. cylinder 1 plug was all dry black carbon, cylinder 2 plug was black carbon but not as bad as cylinder 1. i then pulled plug from cylinder 4 and it still was nice and new looking, no carbon at all on plug. i pulled cylinder 3 plug and its black carbon just as bad as cylinder 1. i now gapped all plugs at .030. do you think the carbon was caused but the un-proper gapped plugs of is it the carbs? if its the carbs, will it need just fuel/air mixture adjustment or will they need to be sync together?
If not aleady done, would ---
Perform compression test;
Assure valve clearances are within specs;
Visually observe for fat blue spark with plugs removed;
Assure timing advancer isn't sticking (lube pivot points; and if needed, remove, clean and lube);
Perform the clear tube test to assure fuel levels are within specs;
Install four brand new NGKB8ES (or as otherwise specified by FSM) spark plugs.
- gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
gengomerpyle wrote: ok ill have to check them. i have BR8ES in the bike now. is it ok to have resistor plugs?....
As to resistance in the so-called secondary loop, the possibilities include:
"R" spark plugs, such as BR8ES;
Suppression core plug wires (as opposed to solid wire core);
Resistor plug boots/caps.
More than one of these usually furnishes too much resistance.
The basic reason for having any resistance is to help avoid producing "radio noise" interference being picked up from the ignition.
I enjoy excellent ignition performance using Dyna solid core plug wires (that come with non-resistor caps already installed) and non-resistor NGKB8ES spark plugs.
Some of the newer audio listening devices are reportedly better shielded from external noise interference.
If the cage guy's zillion decibel boom-box gets all flukey while sitting next to me at a red light, it doesn't give me heart burn.
- gengomerpyle
The basic reason for having any resistance is to help avoid picking up "radio noise" interference from the ignition.
I enjoy excellent ignition performance using Dyna solid core plug wires (that come with nor-resistor caps already installed) and non-resistor NGKB8ES spark plugs.
1982 GPZ750R1 ELR
1971 Honda CB750K
- gengomerpyle
i will go over to the auto parts store and pick up 4 new B8ES plugs. thanks Patton for you advice. this is why i like this forum, always get good advice and help from the members
1982 GPZ750R1 ELR
1971 Honda CB750K
Inadequate voltage at the coil, due to loss of voltage somewhere along the line from battery to coil, may result in weak spark at the plugs.
Air intake might be partially obstructed by something stored underneath the seat, such a gloves or a shop rag.
Oil-type filter(s) might be dirty or over-oiled.
- gengomerpyle
Patton wrote: Would also assure clean and clear air filter(s).
1982 GPZ750R1 ELR
1971 Honda CB750K
- gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
gengomerpyle wrote: ...the last time i filled up i went to non-ethanol gas. do you think that may be causing my problem?
I don't think the type of gasoline is causing the blackened spark plugs or the failure of combustion in a particular cylinder.
Good combustion requires these things:
Fuel (correct air-fuel mixture);
Compression (acceptable compression, accompanied by valve clearances within specs);
Spark (fat-blue spark, and properly timed).
That's the basis for the earlier suggestions toward addressing those requirements.
"Checking" the valve clearances is easy.
Remove the valve cover, and use feeler gauges to measure gap between cam and bucket when the cam is pointed away from the bucket. Perhaps the clearances are okay. But if not, then it gets more involved when needing to replace the shims, and an FSM is definitely needed for guidance.
- gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
