- Thank you received: 1
carb sizes 24-26-28-29 mm see pics ??????????
- indianajames
11 Sep 2011 16:45 #475952
by indianajames
Replied by indianajames on topic carb sizes 24-26-28-29 mm see pics ??????????
they also have a pump .
- Thank you received: 2098
11 Sep 2011 19:25 - 11 Sep 2011 19:25 #475987
by Patton
Replied by Patton on topic carb sizes 24-26-28-29 mm see pics ??????????
Could cut cardboard strips in 22mm and 24mm lengths, and see which one fits through the carb bore on the engine side near the throttle slide.
Last edit: 11 Sep 2011 19:25 by Patton.
The following user(s) said Thank You: indianajames
- gd4now
- Denco where did you go?
- Thank you received: 445
11 Sep 2011 23:46 - 11 Sep 2011 23:50 #476046
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic carb sizes 24-26-28-29 mm see pics ??????????
If they are stock carbs from a kz650 and have the accel pump they are vm24ss carbs. There were 2 models of the 650s that did come with vm22ss carbs but they did not have the accel pump. I have attached a pic of the 22s and 24s, the 24s are on top and do have the pump. One way to tell the difference between the 22s and 24s is that the 22s have an additional vent like opening on the intake side at about 10'olock(see the pic) that the 24s do not have.
I have also created a table of the carbs that came stock on the 650s and have attached it as well.
1977 KZ650 B1
Last edit: 11 Sep 2011 23:50 by gd4now.
