carb sizes 24-26-28-29 mm see pics ??????????
09 Sep 2011 23:09 #475531 by motojunkey
so what your telling me is that the carbs that measure 25.65 on intake side are 24s
the carbs that measure 28.65 are 26s
and the smoothbore carbs i have which measure 29.64 are 29s
is this what I'm understanding from this forum ??????????
  • testarossa
09 Sep 2011 23:15 #475532 by testarossa
Replied by testarossa on topic carb sizes 24-26-28-29 mm see pics ??????????
Left to right in your picture. VM28, VM29 smoothbore, VM24. I don't see any VM26's in the picture.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
The following user(s) said Thank You: motojunkey
09 Sep 2011 23:19 - 09 Sep 2011 23:40 #475534 by motojunkey
Replied by motojunkey on topic carb sizes 24-26-28-29 mm see pics ??????????
what do 26 s look like ?
and what year do they come on --76 900's or later 1000s
do they look like the 28s with an up and down return spring ?
Last edit: 09 Sep 2011 23:40 by motojunkey.
09 Sep 2011 23:28 #475537 by Old Man Rock
Replied by Old Man Rock on topic carb sizes 24-26-28-29 mm see pics ??????????
Maybe this will help....
Z1 carb identification can be found at Z1Enterprises as well....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
09 Sep 2011 23:37 - 22 Jan 2013 03:50 #475539 by martin_csr
Replied by martin_csr on topic .
Last edit: 22 Jan 2013 03:50 by martin_csr.
  • testarossa
09 Sep 2011 23:40 #475540 by testarossa
motojunkey wrote: what do 26 s look like ?
A lot like the VM29's. You will notice the differences in the number of ports on the air filter side, the size of the bore, and the large drain plug in the case of the 29's. VM26's have a small, angled drain plug.
Attachment FEB-008.jpg not found
2004 ZX-10R
Angola, IN
09 Sep 2011 23:45 #475541 by Old Man Rock
I copied to the file base a claeaner version... PDF
Carb Identification
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • wireman
09 Sep 2011 23:48 #475542 by wireman
Replied by wireman on topic carb sizes 24-26-28-29 mm see pics ??????????
those far left carbs in your picture are the 73-75 style 28 carbs,the bottem bowls on the 26s/newer 28s and 29s interchange.
the 26s look basically like the newer 28s,the bodies on 29 smooth bores are made of aluminum versus heavy ass die cast zinc for the 26/28s. B)
the far right carbs are 24s off a kz650
09 Sep 2011 23:51 #475543 by motojunkey
Thank you all !!!
I'm healing up after a crash at gingerman and trying to keep my spirits up while
putting together the next race bike.
With a bunch of time on my hands its great for you guys to cheer me up with a little advice.
now i Know what to look for .
10 Sep 2011 17:02 #475705 by mthure
I've seen some carbs with 3 screws on the top and an accelerator pump, are they 28mm?
10 Sep 2011 17:32 #475727 by Patton
mthure wrote: I've seen some carbs with 3 screws on the top and an accelerator pump, are they 28mm?
Could be 28mm, or 26mm with accelerator pump as used on 79 KZ1000B LTD.
Good Fortune! :)
The following user(s) said Thank You: indianajames
11 Sep 2011 16:41 #475951 by indianajames
Replied by indianajames on topic carb sizes 24-26-28-29 mm see pics ??????????
hey patton , i got some mikunis wiith ribs on them , suposedly from a 1977 650 , they have 102.5 jets . would these be 22mm or something else , cant get a good measurement . no #s on the body or bowls just MC and kogyo mikuni
