what carbs do I have
30 Aug 2011 06:30 #472763 by jeffasaki
Replied by jeffasaki on topic what carbs do I have
you have some 26 mms
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
30 Aug 2011 06:35 #472764 by jeffasaki
sorry didnt see the ribs those are 24s
off a kz650
worth $ 65.00
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
30 Aug 2011 06:36 #472765 by Patton
Replied by Patton on topic what carbs do I have
  • crappiehuntr
  • Topic Author
31 Aug 2011 05:37 #473164 by crappiehuntr
Replied by crappiehuntr on topic what carbs do I have
WOW!!! thanks for all the info. I am having trouble with the stem coming down into bowl from top it is off to the side but sticks down like the center air stem only it has a small hole at bottom goes to the throat other than that they are clean.
1977 KZ1000
1978 KZ650
1976 KZ900 project
1981 KZ550 project
31 Aug 2011 09:33 - 22 Jan 2013 04:43 #473195 by martin_csr
Replied by martin_csr on topic .
Last edit: 22 Jan 2013 04:43 by martin_csr.
  • crappiehuntr
  • Topic Author
04 Sep 2011 03:43 #474121 by crappiehuntr
I Have posted outcome of my carb and bike repair on new members thread thanks for the help guys.
1977 KZ1000
1978 KZ650
1976 KZ900 project
1981 KZ550 project
  • wireman
04 Sep 2011 04:35 #474125 by wireman
Replied by wireman on topic what carbs do I have
H1Vindicator wrote: VM22s probably do too.
not that ive seen anyway
04 Sep 2011 08:36 #474128 by indianajames
Replied by indianajames on topic what carbs do I have
i have some carbs with the ribs on a 77 650 and they mesure 26mm on the inside of the throat and 31.5 on the outside of the throat , both mesurements taken on the side that goes into head boots . seems everybody is saying 22s and 24s have the ribs . do i have 26mm or 32 or what ? not my bike just restoring for a client . anybody?
04 Sep 2011 09:22 - 22 Jan 2013 04:33 #474135 by martin_csr
Last edit: 22 Jan 2013 04:33 by martin_csr.
04 Sep 2011 09:53 #474142 by indianajames
thanks martin , i was confused , cool trick with the cardboard gauge, so 24s have the ribs
08 Sep 2011 23:23 #475271 by motojunkey
Replied by motojunkey on topic what carbs do I have
I also have a extra set of ribbed 26 mm id carbs. 26 on intake side.
it goes to show there's no absolute.
But I'd like to know if the 24 mm intake manifolds that are on the bike.
will accept the 26 carbs or should i buy the kz 1000s 26 mm intake manifolds.
thanks
  • wireman
09 Sep 2011 07:49 #475320 by wireman
show me a picture of a stock set of 26mm carbs with ribs on them,ive played with big bore kaws for 30 years never seen a set of 26s that could be confused with the 24s B)
