- Thank you received: 1
Need help from the carb gods..
- violentvintagecycles
Attachment kz.jpg not found
But, my problem is with a suzuki. An 89 Katana 750. I have a hobby, i pick up 100-200$ jukers, fix em up. Kz was the same, picked it up for 100, this suzuki got for 150. Sitting for awhile outside usual stuff, tank rusted, i por 15ed it.
No airbox, *k&n filters*, jet kit, vance and hines 4-1. Has mikuni bssumthing carbs, cv.. 1st question, the tk carbs on my kz are cv carbs, correct? Note, after por 15, did NOT use inline fuel filters, after it wouldnt idle i re cleaned carbs, put inline filters on, noticed gas was orange and had crap floating in it. <anyone have problems with ethanol?>. Thought por 15 was coming up or.. panicked, cleaned tank out, no rust, not orange, think it was ethanol. Switched to shell 93, thought there no ethanol in it, but.. So, anyway, after cleaning carbs and being hospital clean about it i finally got the thing to idle.
I gotta make this long story short, ive had these carbs off and on a hundred times, tried raising/lowering needles, pilots, fuel screw adjusts, everything, this big black bi&%h just wont run at mid to high rpms. I can roll on, or ease the throttle to get her into high rpms but cant get it to redline, starts stumbling/choking/whatever. Cant floor it, it does the same.. Ever take off on ur kz and forget the choke is on and try to floor it? Very similar.. Hoping u guys can throw some different suggestions other than "put the stock airbox that i dont have back on", ill tell you if ive done it> last 2 things im thinking of trying is lower the mains, have 130's all across, and turn in the fuel screws. Thats my thinking, getting too much gas at high rpms.. Thanks all..
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Might be the ticket - except for the mains likely, which at that time, you can bump maybe 2-3 sizes to try out.
Remember, even though you throw on pods and 4-1 whatever, always start with the stock jetting, and make changes to one component at a time - then test. It will save time in the long run for the extra effort now.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- loudhvx
- Thank you received: 1616
Sorry toget off topic, ...
That green looks fantastic! And wait a minute, that looks like a KZ550D1 frame? The A models had tubular frames holding the rear footpegs. Yours are the aluminum bracket type from a D1 gpz, no?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Thank you received: 2098
violentvintagecycles wrote: ...82 kz550...mikuni bssumthing carbs, cv.. 1st question, the tk carbs on my kz are cv carbs, correct?....
Somewhat difficult to see the carb cover on the handsome green bike pictured, but carbs look to me like manual slide (non-cv) carbs. And not like a CV carb which has a large round cover.
I could very well be mistaken, especially if they are BS carbs, because BS carbs are cv carbs.
- Godfrey
- Thank you received: 10
1981 650CSR frame
1980 KZ750E engine
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
1980 KZ500 B2
- wireman
- Thank you received: 299
im thinking the katana came stock with cv carbs
- loudhvx
Regarding the question about your KZ550 carbs: the 82 KZ550 A3 has TK-22 carbs. They are not CV. There are no diaphragms on the TK-22 carbs. The throttle is all mechanical linkage (rather than vacuum operated).
You can tell modern CV carbs because they have a big, round chamber on top. This houses the diaphragm.
My signature has a link to TK-22 info.
1981 KZ550 D1 gpz.
Other links.
- roundporch
Attachment katknview.jpg not found
Attachment kattankoff.jpg not found
Attachment katdisplayleft.jpg not found
I know the katana has cv carbs, wasnt sure about the kz, there def tk22's, not cv. Reason i asked about that is alot of people telling telling me you cant use pods on a cv carb and i say hogwash. :pinch:
However, i am going to check to see if anything gets blocked by them, as roundporch suggested..
I cant see all the other posts or id quote the guy who said to go back to original settings:
Most is all stock settings, except jet kit, which is at the leanest setting, mains at 130 which im gonna drop, and the fuel screws. Gonna work on that, but not for a couple days.
Start a new job tonight, going from a manager of a dunkin donut to a dump driver. :silly:
Im terrified, almost 40 yrs old..:blush:
- DFIGPZ
- Thank you received: 122
Katana carbs are CV.
1984 750 Turbo
- wireman
dump truck driver? say hello to my buddys at dot/department of trouble/department of tickets! :woohoo:violentvintagecycles wrote: Sorry about that, this is my nightmare bike right now, 89 suzuki katana 750.
