- Thank you received: 18
These carbs are killing me!
- jonnybravo
- Banned
06 Aug 2011 19:02 #467312
by jonnybravo
Replied by jonnybravo on topic These carbs are killing me!
yep that workstestarossa wrote:
matt650csr wrote: That just answered a million questions I had about why so many of these screws were doing that! Where can I find one?
These are supposed to be pretty good: www.ikaswebshop.com/hojisscset4d.html I have no experience with them myself.
Actually, it is said that you can grind a little bit off the tip of a phillips so that it seats fully down into the JIS screw. This will help quite a bit if you are in a pinch. I would just grind the tip a small amount at a time until you can see that the screwdriver is fully seated in the screw. I doubt that you will be able to find a JIS at your local home improvement store. Reportedly, electronics stores sell JIS drivers in smaller sizes, as a lot of electronics take small JIS screws.
- jonnybravo
- Banned
06 Aug 2011 19:03 #467313
by jonnybravo
did that one tooGodfrey wrote: Once you get them all out , you might consider investing in socket head cap screws as replacements, I have much better luck with allen wrenches then phillips head screw drivers
