z1000 mk2 using tm33's
19 Jul 2011 19:11 #463819 by crackfox1
z1000 mk2 using tm33's was created by crackfox1
Hello, I've just joined the group and would welcome jetting advise from anyone running tm33 flat slides on their kz1000. I've aquired a set off of ebay from an english gsxr750 from around 88 or 89. however their not performing as they should. Apart from the first carb from the left being totally blocked (due to the choke slide being broken and jammed on full choke) I've just noticed they're running 97.5 main jets. (30 below stock). I'm waiting to find out what bike these were actually used on last. Well to get to the point. I've fitted these to a de-shafted 79 z1000st (english) with a standard bore size 1015cc with a ported head to suit these carbs. Could anyone recommend what main jet's I should use for this application ? i've heard that the stock 127.5 could be too large for street use as they'd regularly choke-up in traffic on the late eighties gsxr's they were intended for. Thank you. simon. newcastle upon tyne, england.
  • KZ_Rage
  • Kentucky Bourbon Barrel Ale
19 Jul 2011 21:45 #463837 by KZ_Rage
Replied by KZ_Rage on topic z1000 mk2 using tm33's
Sorry, can't help you with the jets and such on those carbs but I am very interested in the de-shafted E!
Care to post some photos of that?
Oh and welcome to the forum, no toga required!:lol:
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
19 Jul 2011 22:03 #463840 by cavanaughracing
Replied by cavanaughracing on topic z1000 mk2 using tm33's
crackfox1 wrote: Hello, I've just joined the group and would welcome jetting advise from anyone running tm33 flat slides on their kz1000. I've aquired a set off of ebay from an english gsxr750 from around 88 or 89. however their not performing as they should. Apart from the first carb from the left being totally blocked (due to the choke slide being broken and jammed on full choke) I've just noticed they're running 97.5 main jets. (30 below stock). I'm waiting to find out what bike these were actually used on last. Well to get to the point. I've fitted these to a de-shafted 79 z1000st (english) with a standard bore size 1015cc with a ported head to suit these carbs. Could anyone recommend what main jet's I should use for this application ? i've heard that the stock 127.5 could be too large for street use as they'd regularly choke-up in traffic on the late eighties gsxr's they were intended for. Thank you. simon. newcastle upon tyne, england.
I'd start right there with the 127.5 and see how you make out. Better a little fat than lean ;)
20 Jul 2011 15:34 #463977 by crackfox1
Replied by crackfox1 on topic z1000 mk2 using tm33's
These are the best pics I could get in my cluttered garage but should have it on the road in the next couple of days. I've just put 120 main jets in out of my vm26's making a vast improvement. The only problem I now have is the third and fourth pot are getting more fuel than the first and second. I think this is down to the choke having been stuck on full on the first carb causing the pump piston to seize up. I've cleaned it up but its not performing as well as the pump in the fourth carb. I've still got to paint the bike (probably black) using the white ltd tank instead of the original. Thank you. simon.
20 Jul 2011 15:35 #463978 by crackfox1
[attachment:1]C:\fakepath\z1 005.jpg[/attachment]
[attachment:2]C:\fakepath\z1 004.jpg[/attachment]
[attachment:3]C:\fakepath\z1 003.jpg[/attachment]
[attachment:4]C:\fakepath\z1 001.jpg[/attachment]
20 Jul 2011 15:38 #463980 by crackfox1
Not sure what happened there, wheres my pics ?
20 Jul 2011 15:42 #463981 by crackfox1
try again
[attachment:3]C:\fakepath\z1 004.jpg[/attachment]
20 Jul 2011 15:57 - 20 Jul 2011 16:01 #463983 by 531blackbanshee
Replied by 531blackbanshee on topic z1000 mk2 using tm33's
this link should be the pic post tutorial.
kzrider.com/forum/8-about-the-site/44597...s-after-site-upgrade
Last edit: 20 Jul 2011 16:01 by 531blackbanshee.
21 Jul 2011 17:46 #464146 by crackfox1
Thanks for the info leon. Thats how i've been trying to download pics but for some reason it keeps coming up something about exceeding the megabytes for a file download.
21 Jul 2011 18:53 #464155 by Patton
Replied by Patton on topic z1000 mk2 using tm33's
Although oversize images are usually automatically reduced and shown by KZr, try reducing image to these limits:
Width: 2400px
Height: 1200px
Size: 2048kb (2 MB)
:unsure: Don't know what's causing the "fakepath" image name.
Good Fortune! :)
22 Jul 2011 00:12 #464201 by jeffasaki
Replied by jeffasaki on topic z1000 mk2 using tm33's
97.5 are the stock 1988 gsxr 750 mains
you have a lot of room and opions avaiable to play with these carbs
GOOD CARBS ARE HARD TO FIND
you have found a set
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
22 Jul 2011 00:28 #464204 by jeffasaki
PS if you are gonna put these old GSXR carbs on a KAWASAKI
I would first introduce them to your KAWASAKI gently
Make sure that the KAWASAKI dosent just look at them and say
"Do I really wanna make a suzuki fart?"
I remeber being on a hunting trip
I rode my old KAWASAKI to the tree stand
Just as I was about to shoot a 12 point buck
I saw something out of the corner of my eye
It was my KAWASAKI killibg a family of young suzukis
Anyway I let the buck go and observed the natural order of life
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
