SOS carbs possibly
- faceplant15000
- Thank you received: 2098
faceplant15000 wrote: So I just traded for a 1980 kz440 LTD A1 and im have a bit of an issue. When i start the bike and give it gas the rps jump to around 5000rpm and stay there. I do know that the clutch lever is sloppy but I can help but think this is a carb issue. Any help is very appreciated.
Perhaps an air leak through old hard cracked carb holders.
One testing technique is to spray WD40 around the carb holders while the engine is idling, and watch for smoke from the exhaust which indicates that the WD40 is being ingested and combusted.
Might also be a mechanical malfunction in the throttle mechanism, such as a throttle cable adjusted too tightly, or an internally frayed throttle cable, or need to lube the cable, or kinked cable, etc.
- Thank you received: 1656
- faceplant15000
- faceplant15000
faceplant15000 wrote: Ok so i looked at everything today no vacuum leaks and the air box in installed correctly but one of the carbs fuel lines was plugged and now im trying to figure out exactly how they go. Also under the gas tank is a big line that i cant figure out where it goes. So if anyone could tell me the position of the fuel line it would be a huge help. the way there ran now is carb 1 and are connected via splitter and run to the petcock then there's another that runs from the petcock to in-between the carbs and there are 2 on the bottom of the carb at are run together.
The line in question will likely appear on the applicable parts diagram which will also include the name of the line.
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
The line might be cracked or fitted too loosely at the carb or petcock.
Racing idle, absent vacuum leak, casts increased suspicion toward a mechanical malfunction in the throttle mechanism, such as a throttle cable adjusted too tightly, or an internally frayed throttle cable, or need to lube the cable, or kinked cable, etc.
- GPz550D1
- Thank you received: 22
1981 KZ550-D1
- GPz550D1
1981 KZ550-D1
- joshreynolds92
- VWCABRIOLETLVR
My love for Volkswagon and Honda is strong but my love for Kawasaki's is soo much stronger
- faceplant15000
