1980 KZ1000G need help!
27 Jun 2011 21:06 #459817 by TexasKZ900
Replied by TexasKZ900 on topic 1980 KZ1000G need help!
Thanks, for the info.
I replaced all the fuel lines this past weekend, with good quality fuel injection hose from the local auto parts store.
I found some info about the pump I'm going buy:
Attachment GSL393-specs.jpg not found
This means peak amps should be 13.5, is that correct, based on the picture?
27 Jun 2011 21:10 #459819 by MFolks
Replied by MFolks on topic 1980 KZ1000G need help!
I see around 8 amps at 33-35 PSI, but I'm no chart expert.
  • Motor Head
29 Jun 2011 00:34 #460066 by Motor Head
Replied by Motor Head on topic 1980 KZ1000G need help!
You may have to re-do the inlet with a 90 degree fitting. But otherwise that pump is actually more than enough to run you bike. Looks like when running and regulated the Amps will be 4 or so. Your Stator/ charging max rated output is 20 Amps. So I think you would be OK if it is in good shape. You could take a draw measurement or the existing circuits for a total. Try to stay below the Max output of 20 or it won't last, the stator will burn out. You can get an over wound stator which will handle extra load/ Amps.
30 Jun 2011 17:15 #460314 by TexasKZ900
Does anybody know what the exact amps are for the Kawasaki fuel pump?
Attachment IMAG0258_2011-06-30.jpg not found
Thanks,
Dirk
30 Jun 2011 18:42 #460326 by MFolks
I think the wiring for the pump power is probably 18 gauge(That's pretty close as the Kawasaki wiring is metric)
  • Motor Head
01 Jul 2011 00:37 #460397 by Motor Head
The exact Amperage is like your chart a variable. But if you look at the circuitry of the pump, and the rated fuse, you will see that its not a lot. I've dead headed many electric fuel pumps to check the max pressure and the Amp draw. Not many exceed 8 Amps blocked, dead headed. The stock pump would most likely be around this and below, depending upon demand/ pressure. Regulated down to the Stock pressure of around 35psi, it would be about 4-5 Amps. That's my experience, but not with that exact pump.
01 Jul 2011 23:49 #460578 by TexasKZ900
Thank you both for you help, I'm not a mechanic and my sons and I are learning as we go.:)
Thanks again,
Dirk
