- Thank you received: 1
installed factory air box today
- bigkzfan
- if grandpa had tits he"d be grandma, if
22 Jun 2011 22:38 #458807
by bigkzfan
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
installed factory air box today was created by bigkzfan
well i done away with the pod filters on my 82 j model and now i wonder what i was think for even taking it off!!!! resynced the carbs and wow what a difference!!!!!! if your trying to run pod filters on these cv 34 carbs do you self a favor and install the air box!!! i do have new intake manifolds and new intake boots and man money well spent!!!!!!!! and it has a dyno jet kit in it with 135 mains i believe.. i went with the middle main jets in the kit...cylinder head had 3 angle valve job, new viton valve seals, a.p.e valve guides, all new cam chain guides, a.p.e manual cam chain adjuster new piston rings block off plates, new fork seals new dyna coils, taylor wires, new high flow petcock god i got some money in this old girl lol
- Thank you received: 2829
22 Jun 2011 22:57 #458814
by 650ed
Replied by 650ed on topic installed factory air box today
Congrats on coming back to the airbox! I'd love to see someone do a pods vs. airbox comparison on a dyno that shows the full power curve from idle to redline. I'm sure the airbox would show more consistant power across the range. Ed
- bigkzfan
22 Jun 2011 23:05 #458815
by bigkzfan
Replied by bigkzfan on topic installed factory air box today
there is no doubt in my mind about that!!!!! major improvement thru rpm range!!!!! just kinda makes me mad i have a brand new set of ape air filters that are now on the shelf!!!
- cavanaughracing
- Banned
22 Jun 2011 23:51 #458826
by cavanaughracing
Larry C.
cavanaughracing.com
Replied by cavanaughracing on topic installed factory air box today
This should be a sticky if I ever saw one Smart move!
Larry C.
cavanaughracing.com
- bigkzfan
22 Jun 2011 23:51 #458828
by bigkzfan
the air box is the only way to go!!!!!!! with these carbs!!!! i cant afford 600 dollars for smooth bores!!!! )
- bigkzfan
22 Jun 2011 23:55 #458829
by bigkzfan
lol i just know the difference it made to me!!!! i really like the design of that air box.. obviously after i went thru the misery of trying to tune these carbs with pod filters.. never again
- Polar_Bus
- Thank you received: 7
23 Jun 2011 07:34 #458862
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Replied by Polar_Bus on topic installed factory air box today
Isn't it just the greatest thing to read a post that says "wow my stock airboxed KZ runs the balls" ?? Now if we could just sucessfully beat some sense into the other 95% of the "pod junkies" :laugh:
Bikes:
'84 GPz1100
'06 HD Fatboy
- Motor Head
- Thank you received: 391
23 Jun 2011 09:14 #458867
by Motor Head
Replied by Motor Head on topic installed factory air box today
Looks as though there will be plenty of riding, instead of carb tuning for you this year.
Does it run good with those big 135 mains? Sounds like that is a pretty big jet. Maybe you don't run with the "Snorkel" that comes out the rear/ intake of the box?
- bigkzfan
23 Jun 2011 09:51 #458876
by bigkzfan
ran the best that it has in a long time...i even bumped them main jets down to the middle size..the kit came with 3 different main jet sizes...i also set the float levels with the clear tube method..
- bigkzfan
23 Jun 2011 09:53 #458878
by bigkzfan
it will never see pods on these style carbs again!!!!!! i also synced them again when it was all back together with factory air box
- bigkzfan
23 Jun 2011 09:54 #458880
by bigkzfan
yes thats with the rubber snorkel under seat on it also..im just happy i didnt pitch it all
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
23 Jun 2011 10:02 #458881
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic installed factory air box today
Shhhhhhhhhh! Everyone will be doing it .....
If everyone starts running airboxes there won't be as many people getting rid of their bikes cheap because they can't get them to run well or are sick of fiddling with them.
Plus I really looked forward to people making statements like "My bike runs great with PODS...except for that large hickup or flat spot or wind problem. But really other than those things it really runs great!" Comedy at it's best.
Hey some people like to fiddle with things and some may not even notice the drawbacks because the pods look cool. 2 each their own
