BS34 Air Leak Locations ?!?! >(
  • TeK9iNe
  • Topic Author
  • What did you do!?!
04 Jun 2011 18:03 #455417 by TeK9iNe
Replied by TeK9iNe on topic BS34 Air Leak Locations ?!?! >(
Damnit I still cant find a leak anywhere. This is really pissing me off.
Anyone else have any suggestions as to a location for air intrusion on these BS34's???
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Motor Head
04 Jun 2011 18:42 #455421 by Motor Head
Replied by Motor Head on topic BS34 Air Leak Locations ?!?! >(
Have you had the carbs off and measured the butterfly to bore on each, to see if the offender is getting more air/ signal?
  • Grantl
  • KZRider is Da Bomb!!!
05 Jun 2011 12:14 #455586 by Grantl
Replied by Grantl on topic BS34 Air Leak Locations ?!?! >(
Have you checked the diaphragms for pin holes?
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
05 Jun 2011 22:58 #455682 by JR
Replied by JR on topic BS34 Air Leak Locations ?!?! >(
I've had an annoying little spit back through either #1 or #2 carb this past few weeks. Only noticeable when I started the bike first and the choke was on. I played with the mixture screws and no good. I was confident the vacuum caps were solid but I got new ones on Saturday morning anyway and put them on. Also replaced the vacuum line to petock as I think the hose clip had gouged a wee hole. I think it's fixed. I hope it's fixed. Replacing the vacuum caps was $5 . worth a try ?
  • TeK9iNe
  • Topic Author
06 Jun 2011 18:17 #455818 by TeK9iNe
Motor Head wrote: Have you had the carbs off and measured the butterfly to bore on each, to see if the offender is getting more air/ signal?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • Topic Author
06 Jun 2011 18:18 #455819 by TeK9iNe
Grantl wrote: Have you checked the diaphragms for pin holes?
Yes, and I even swapped a couple (though you shouldnt), and it still didnt help.
Put them back afterwards...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • Topic Author
06 Jun 2011 18:19 #455820 by TeK9iNe
JR wrote: I've had an annoying little spit back through either #1 or #2 carb this past few weeks. Only noticeable when I started the bike first and the choke was on. I played with the mixture screws and no good. I was confident the vacuum caps were solid but I got new ones on Saturday morning anyway and put them on. Also replaced the vacuum line to petock as I think the hose clip had gouged a wee hole. I think it's fixed. I hope it's fixed. Replacing the vacuum caps was $5 . worth a try ?
Swapped the vacuum caps (all four capped w/on - off petcock). Still no change... :( :angry: :silly:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • Topic Author
06 Jun 2011 18:21 #455821 by TeK9iNe
Thanks for all the replies, but the problem still persists.
I just cant figure out where the extra air is coming from.
It's a strange mystery defying my sense of being!
:P
Still runs good, once tuned up - just frustrated the hell out o' me.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
