BS34 Air Leak Locations ?!?! >(
  • TeK9iNe
  • Topic Author
  • What did you do!?!
02 Jun 2011 18:05 - 02 Jun 2011 18:08 #455013 by TeK9iNe
BS34 Air Leak Locations ?!?! >( was created by TeK9iNe
Got a set of BS34s that have developed an air leak on the 2nd cylinder/carb.
Not the usual location (carb to engine, or airbox boots), somewheres different.
Compression is 147, valves .003 intake, .004 exhaust, rest of engine equally sound.
The leak is very small and only really detectable at, or just off idle (as usual duh!) :silly:
I can get all other carbs perfect at around 1.8 - 2 turns out, but this carb needs to be about 3.5 - 3.75 turns out to achieve best idle mixture (when compared to others) through a colortune plug.
Not detectable with propane or WD40 or the like, and no reeming/destruction of the air bleeds/jets has taken place... no visible loss of parts or damage anywhere. I have swapped mixture needles, pilots, washers, orings, etc - STILL NO DAMNED EFFECT!... ehem sorry :)
WHA!!??
Anyone with a new thought... more insight would be greatly appreciated.
Thanks!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 02 Jun 2011 18:08 by TeK9iNe.
  • wireman
02 Jun 2011 19:07 #455024 by wireman
Replied by wireman on topic BS34 Air Leak Locations ?!?! >(
wg.com
  • hocbj23
  • Visitor
02 Jun 2011 20:17 #455047 by hocbj23
Replied by hocbj23 on topic BS34 Air Leak Locations ?!?! >(
#2 on my J bike is where the vacuum line for the petcock fits.I am running a Pingel so dont use the vac port and have it plugged.Have u checked the vac port? How about an exhaust gasket leak on the opposite side of the mota?bj
  • TeK9iNe
  • Topic Author
02 Jun 2011 20:38 #455050 by TeK9iNe
Replied by TeK9iNe on topic BS34 Air Leak Locations ?!?! >(
That helps. Some website about money lending...
If you mean wiredgeorge, then yeah, I suppose he could respond to an email in august some time... :laugh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • Topic Author
02 Jun 2011 20:39 #455052 by TeK9iNe
hocbj23 wrote: #2 on my J bike is where the vacuum line for the petcock fits.I am running a Pingel so dont use the vac port and have it plugged.Have u checked the vac port? How about an exhaust gasket leak on the opposite side of the mota?bj
No exhaust leak, and I'm running a non-vac setup petcock as well. All vacuum nips are capped.
Thanks.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • wireman
02 Jun 2011 20:50 - 02 Jun 2011 20:54 #455054 by wireman
TeK9iNe wrote: That helps. Some website about money lending...
B)
ok wgcarbs.com
or magnum fours performance in vendor directory,ask Otto
Last edit: 02 Jun 2011 20:54 by wireman.
  • Grantl
  • KZRider is Da Bomb!!!
03 Jun 2011 00:11 #455101 by Grantl
Replied by Grantl on topic BS34 Air Leak Locations ?!?! >(
Maybe the rubber boot for the choke rod? Although I haven't detected any air leaks from that location, it looks like that is a likely area where an air leak could start. My BS34's seriously need these boots replaced.
Best of luck, and let us all know if you find the source of your air leak.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
  • Motor Head
03 Jun 2011 00:18 #455102 by Motor Head
Replied by Motor Head on topic BS34 Air Leak Locations ?!?! >(
Slide set higher? Stronger air flow past slide = more fuel needed. Got a Manometer?
O-ring @ mix screw in good shape?
I spray a bit of carb cleaner around for air leaks.
  • TeK9iNe
  • Topic Author
03 Jun 2011 07:59 #455139 by TeK9iNe
Grantl wrote: Maybe the rubber boot for the choke rod? Although I haven't detected any air leaks from that location, it looks like that is a likely area where an air leak could start. My BS34's seriously need these boots replaced.
Grant.
I've run without them, without any ill effects... I guess the machined plunger and pad works fine - I suspect they are just dust boots.
Thanks.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • Topic Author
03 Jun 2011 08:07 #455140 by TeK9iNe
Motor Head wrote: Slide set higher? Stronger air flow past slide = more fuel needed. Got a Manometer?
The BS34s are CV carbs with throttle butterflys, but your thought is correct (...butterfly opened to much). I have the carbtune pro 2 manometer I use in conjunction with a colortune plug. With the carbs perfectly synced, (can just barely slide a paper test strip under all four at idle) the result is the same with the colortune plug, or using old method with the ear.
I have found that the sync settings do affect the mixture slightly, but this is a bit more than usual. No results as of yet with spraying stuff around - external leak seems non existant or undetectable.
Thanks.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Motor Head
03 Jun 2011 09:31 #455146 by Motor Head
Oh I Messed that up, I did mean the throttle, but the shaft that the butterfly sits on. It has seals where it goes through the carb body, on the outside. Last time I tried to get those little seals it was a huge PITA.
Just too many brews last night, :blink:
  • TeK9iNe
  • Topic Author
03 Jun 2011 19:25 #455222 by TeK9iNe
Motor Head wrote: Oh I Messed that up, I did mean the throttle, but the shaft that the butterfly sits on. It has seals where it goes through the carb body, on the outside. Last time I tried to get those little seals it was a huge PITA.
Right, i see what you're saying. Well I guess I could try to spray things around again and look more carefully. I havn't had much luck with the spray and pray so far, but soaking those area might prove to be the ticket.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
