Machining Project: Boring VM26 Carbs To 29mm
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Machining Project: Boring VM26 Carbs To 29mm
21 Jan 2012 10:21 - 21 Jan 2012 10:21
#499177
First off, D that is amazing work you have going on there... B)
Now I'n not in the market to replace my beloved CR29's but rough guesstimate (no quote), what would something as such run us ($$$)?
Example <=$500 where the buyer supplies a set of 26mm core's and they get your modified 29mm...
As mentioned not needed now but my 900 won't be the only KZ I build for have a titled frame staring me down. And I have 2 sets of 26mm carb's sitting there... :laugh:
If your not comfortable replying to this or if against forum rules, that's cool as well where I'll pm when the time comes... All good! ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 21 Jan 2012 10:21 by Old Man Rock.
  • DoubleDub
  • DoubleDub's Avatar
21 Jan 2012 11:39
#499187
I think a number of people (...) would also be interested in this service.
I also notice that WG seems to think that the fuel rail size in the carb body needed to be increased when he built his 29+mm carbs - any idea if that is necessary?
From his site:
We choose the nicest core assemblies and perform our cleaning magic, rebuild and bore the venturis to just under 30mm. We then install high flow fuel rails and make some other internal modifications which we prefer not to disclose.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Jan 2012 19:11
#499282
DoubleDub wrote: I think a number of people (...) would also be interested in this service.
From his site:
what size is the rail??? i ran stock 1/4 fuel line and petcock on my old 1135cc motor , if that helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • dshelly
  • dshelly's Avatar Topic Author
21 Jan 2012 20:00
#499293
For more information on these all. Feel free to send me a PM. OMR I just sent you one.
Hopefully this isn't against the rules. :)
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • notaduc
  • notaduc's Avatar
23 Jan 2012 16:02
#499627
Brought this thread back from the dead...
1980 (mostly) KZ1000
  • jeffasaki
  • jeffasaki's Avatar
23 Jan 2012 17:42
#499647
Nice work
Be cool to flow test em beside a set of OEM 29s
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • hotrods316
  • hotrods316's Avatar
15 Jan 2014 14:14
#618751
i just found this thread. I am trying to find the earlier writeup from dshelly. I know I will get scorned, but I came from a zooki site. I would like to try this on a set of carbs for one of my gs1000s. I have a dumb question, what is the procedure for removing the needle jet brass insert in the bottom of the carb body before you bore. Also any tips and tricks on how to accomplish this boring process would be greatly appreciated. I am a hobbyist machinist/racer, have bridgeport and lathe todo this task. Thanks so much
Matt
  • zed1015
  • zed1015's Avatar
15 Jan 2014 15:30 - 15 Jan 2014 15:38
#618759
Just lightly tap the needle jet out toward the float bowl from the venturi side.
More carb boring details in my project thread ....
HERE. Page 11 and 13.
www.kzrider.com/forum/11-projects/395445...-who-knows?start=200
Last edit: 15 Jan 2014 15:38 by zed1015.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
15 Jan 2014 15:41 - 15 Jan 2014 15:43
#618760
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is an interesting read. If you open and read the description, cheaper than 29's
Last edit: 15 Jan 2014 15:43 by 4TheKZ1000.
  • Harvey1327
  • Harvey1327's Avatar
15 Jan 2014 18:17
#618770
4TheKZ1000 wrote: This is an interesting read. If you open and read the description, cheaper than 29's
Also sells X-pipes?
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • greenman43
  • greenman43's Avatar
16 Jan 2014 22:57
#618912
I'm certainly no engineer, but I can't see how an engine can flow any more than it's worst flowing component. He's suggesting that if oem carbs flow 70 cfm and the head 68 cfm, bolting on modified carbs will somehoe improve it, but surely the restriction is at the worst point ?
Cheers,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
17 Jan 2014 05:36
#618926
Cheers,
Brian
you have to remember velocity when talking about port flow.
