Machining Project: Boring VM26 Carbs To 29mm
- dshelly
23 May 2011 13:32
A while back I wrote a small piece on boring carb bodies. With the current price of 29 Smoothbore carbs lately I figured I would try boring out a set of 26mm to 29mm and see what happens. Some of you wanted pictures (as always) so here are a few shots of the carbs getting machined. Just so you understand what your looking at . The first pic is in my CNC Lathe getting bored to the 29mm diameter. The next is in the mill getting the recess in the bottom cut deeper. This is a critical step , if you don't do this the slide won't drop far enough and the bike won't idle under 2500 rpm. I have a set of these on two of my bikes and it make seems to make quite a difference.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- dshelly
Re: Machining Project: Boring VM26 Carbs To 29mm
23 May 2011 13:35
After machining you have to raise the needle to the bottom clip . Since now the slide sets lower in the bore, otherwise it will be way too rich. So what do you guys think?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Kidkawie
- I bleed premix
23 May 2011 13:45
Does the slide clear the top of the carb?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- T_Dub
23 May 2011 13:56
I think its cool but I want moar pics!!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- dshelly
23 May 2011 13:58
Yes, the slide only sits aproximately .07 lower in the bore. There is plenty of range of motion to get slide all the way open.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- dshelly
23 May 2011 14:08
More pics? OK here is 1 more showing the difference in bore size. 26mm on the left 29mm on the right .
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- T_Dub
23 May 2011 14:09
Looking good. Have you used them yet? Results?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- dshelly
23 May 2011 14:16
Yep, put them on my 77 kz1000 1015cc with 10.25 wisecos. Pulls great! runs better than ever.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- T_Dub
23 May 2011 14:17
Excellent! Always nice to have something work out that well!
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- hocbj23
- testarossa
23 May 2011 16:38
Excellent info Dshelly. I'm glad to see that I'm not the only person on here who's not afraid to do a little Mikuni machining.
Did you chuck directly on the casting where the carb boot would normally clamp, or is that a jig that the carb bolts to for the lathe work? Do you find that the carb bore is fairly concentric to the outside of the casting for the boot?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
23 May 2011 16:52
it looks as though you did not offset the bore at all,is this true?
was the clip change and the machine work the only things that changed?
i am glad that you have done this and posted the pics,
thanks for answering the questions as well.
