Machining Project: Boring VM26 Carbs To 29mm
  • dshelly
  • dshelly's Avatar Topic Author
Re: Machining Project: Boring VM26 Carbs To 29mm
23 May 2011 22:31
#453146
the fixture in the lathe has clearance for where the boot attaches and it bolts directly to the flange. Then I clamp the fixture in the chuck.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • testarossa
  • testarossa's Avatar
23 May 2011 23:51
#453180
Good thinking! If you clamped on the casting directly, you might get an egg shaped bore since those bore walls get pretty thin by the time you get to 29mm. Seems to me that most CNC lathes don't allow you to turn the chuck pressure too far down. I like how your jig eliminates that problem. Nice work. I might try this on my old 26's sometime in the future. It would be nice to compare them to my 29's that are on the bike now.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • zed1015
  • zed1015's Avatar
24 May 2011 08:18
#453219
dshelly wrote: After machining you have to raise the needle to the bottom clip . Since now the slide sets lower in the bore, otherwise it will be way too rich. So what do you guys think?
Very nice job :cheer: but surely you mean way too weak ?
Raising the needle richens ;)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
24 May 2011 08:48
#453222
great job. why didnt u start with 28's? are they harder to find ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • dshelly
24 May 2011 10:14
#453234
You're right zed1015 way to weak. Since the slide drops down .07 you have to raise the needle to compensate. Yes, mark1122 the 28's seem to be harder to find and more money. You can pick up a set of 26's on Ebay pretty cheap.
I did forget to mention that the set I show in the pics was bored out to 29.5mm . That's the biggest you can go, there just isn't enough material to go any larger. The wall thickness around the flange gets too thin and when cutting the bottom you don't want to punch through into the bowl.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • notaduc
  • notaduc's Avatar
18 Jan 2012 15:54
#498678
WHat sort of tool are you using on the mill here?
How did you decide to deepen the groove as opposed to modifying the slide?
1980 (mostly) KZ1000
  • harm
  • harm's Avatar
  • Tom
19 Jan 2012 14:51
#498904
Nice Work!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • dshelly
19 Jan 2012 15:57
#498910
notaduc wrote: WHat sort of tool are you using on the mill here?
By just machining the body only eliminates having to mess with the slide. However since the slide goes down farther in the body , you have to move the clip to the bottom notch. This raises the needle close to where it was to start with before boring.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • dshelly
19 Jan 2012 15:59
#498912
By the way, the cutter is "top secret". :) I do this for a living you know.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • david1050
  • david1050's Avatar
19 Jan 2012 16:12
#498915
Nice job
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
  • notaduc
  • notaduc's Avatar
20 Jan 2012 14:12
#499059
I do this for a living too...
20 Jan 2012 15:18
#499068
Interesting reading about the bored-out carbs, but have not yet tried them.
www.wgcarbs.com//index.php?option=com_co...view&id=14&Itemid=29
Scroll down to "Mikuni VM30 Performance Special"
Good Fortune! :)
