Pod filters re jet cv carbs
- Proxy
- 80% Human 20% Nuts/Bolts
Re: Pod filters re jet cv carbs
02 Jun 2011 09:56
"there aren't many dirt roads in tennessee"
I'm telling you this child is FUNNY!
"must be retired" OH my sides!:woohoo: :woohoo: :woohoo: :lol: Make him stop!
In all seriousness. Good luck with the bike. Oh yeah good luck with the attitude too. Both should take you a long way.
FYI I am retired. Pretty young too. I was unlucky to have a pretty bad accident but lucky that I was in a position to to retire. May you have the same luck.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- Sackman
02 Jun 2011 14:48
Can't we all just get along?......probably not now that I think about it.
Check out my blog at backyardbikechoppin.blog
or
Sackmans Choppers
77 KZ 650 Chopper
84 Honda Nighthawk Chopper
98 Vulcan 1500 Classic
or
Sackmans Choppers
77 KZ 650 Chopper
- gumby prichard
05 Jun 2011 01:37
I could care less about making some pen pals homie. I just wanted some info. And so far have gotten it.
I'm glad you losers have time to waste on a computer all day. Congratulations, but it's hard working a full time job to support yourself and going to school, along with finding time to finish this bike. Sorry I don't have time to beg for your approval, and I could honestly care less to.
SO back to the matter at hand, I just adjusted my float levels. They were wayyyy low. Most likely going to have to rejet. Painting the frame soon, and then I will reassemble and see how it comes along....I will post the final product and specs next time.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
05 Jun 2011 10:41
Yes, by all means post pictures of your machine, and don't forget to ask us loser homies for advice in the future. We are here to serve winners like you.
- gumby prichard
18 Aug 2011 02:25
i have found the perfect mixture! :]]]]] using uni pod filters. i will post it when i take my carbs apart....i havent gotten any lein spots at all and plugs are not black. I began restoration about three months ago after noticing a blown cylinder gasket.......and now i can't find piston rings for it :[[[[[[
any info helps. thanks
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Proxy
18 Aug 2011 09:15 - 18 Aug 2011 09:18
Last edit: 18 Aug 2011 09:18 by Proxy.
- gumby prichard
26 Nov 2011 05:48
I was running 100 main, 35 pilot, and whatever the stock secondary jet was.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
The following user(s) said Thank You: be.rad.82
- be.rad.82
19 Jan 2012 15:57 - 19 Jan 2012 16:26
Grumbly Prichard, Like the idea on this post.. Did you adjust/shim the needles at all??
I believe I have a similar set up. 82 440 LTD with UNI Pods. I currently have 92 mains and other jets are stock. 68 I recall for the other main and 35 for pilot. I also shimmed the needles with a very small washer. It idles well. . kind of rough when revving from idle to 1/3 throttle.. (cold or hot engine temp). It runs best when FULLY warmed up. top end feels excellent and mid throttle is quite good.
Looking into what reasonable adjustments I can make to the needles.. I know my problem area can be tuned with them by needle height and shape.
Would love to know more about what you have and any updates on your project too.
I just received my new seat in the mail and will be cutting up and modifying the rear of the frame to mate with my new seat's pan soon.. Looking forward to that!
Can't seem to locate a replacement/larger size jet for my 35 pilot. Any one know where I can? Jetrus doesn't have it.
Last edit: 19 Jan 2012 16:26 by be.rad.82. Reason: accuracy
- kzc278
25 Jan 2012 19:05
gumby,
nobody replied, nobody is interested, you have discovered nothing with your "pod made to work correct" thread.. all you have done is get your bike to RUN, i bet it runs crap, flat spots, pops on deceleration etc. what you rudely dismissed was years of knowledge, yeah, i am old, had a kz650 new when i was 18..........facts are, CV carbs work best with standard airbox, same with Honda, Suzuki, Yamaha. the slides need vacum to lift, too much air thru a pod does not provide enough vacum, simple as that.bye gumby
kz650c2 1978
cb750kz 1979
xj650rj 1982
cb750kz 1979
xj650rj 1982
- TomasDouglas
12 Dec 2013 19:39loudhvx wrote: The best way is to use the clear tube method which lets you see the actual fuel level. I beleive Patton (moderator on this site) has a good illustration of the method. A fitting gets connected to the drain screw port on the bowl and a clear tube is fitted and held vertically. Gasoline will be seen in the tube at the same level that it is in the bowl. The tube must have at least a 1/4" or bigger diameter at the point where the gas level is otherwise capillary action will give a false reading. Since the tube connected to the carb may be rather small, I just stuff the small tube into a bigger diameter tube so the reading is accurate.
Thanks for the links at the bottom of your message. I was given a 1980 KZ550 that hasn't run in a dozen years and I am attempting to rebuild it. I have been trolling KZ Rider for all the information I can get and your posts with your advice and your links with manual, carbs, etc. will be invaluable to me.
Thanks
Tomas Douglas
1980 KZ550A
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
1980 KZ 550A
1986 GPZ 550
- guitargeek
12 Dec 2013 21:17
Lou is a very valuable community resource!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- kawi810
13 Dec 2013 04:45
back in 1984 i purchased a brand new gpz 750 .the first thing i did was put a vance & hines 4 -1 pipe on and a dynojet stage 3 jet kit with k&n individual air filters.the bike ran great for years .never had a problem tuning the carbs. there is one thing i noticed that came in my kit were lighter diaphragm SPRINGS and a drill to open up the lift hole in the slides .todays kits do not have the springs listed in the kit.for the mikuni bs 34 cv,s for the 1984 gpz 750 i just wonder if the problem with throttle response is due to to heavy a spring in the slide/ diaphragm .can any body tell me what they have installed in there carbs?
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
