- Thank you received: 3
kz1000 + bs34 cv carbs/pods clarification.
- notaduc
I think I meant gs1000.
1980 (mostly) KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Kraz1
I run a set of the Mikuni BS34s on my Built GPz1150 with .420 cams and oversize valves and flowed head and I will put my bike up against anything that runs smooth-bores on the street.
I'm up for that, GPz1150 vs GS1150 with mild Cams and 40mm Radial Smooth Bores for the "Street". :kiss:
GS1150 <Clicky
- PLUMMEN
- Thank you received: 103
thats the same head as a 79-80 ltd or kz,unless he plugged the injector ports.That is not an older stile head. That is still a MKII head from 1979-81. You should have no problem using the cv34 carbs. As I mentioned before, get a Mikuni set from a GPz750.
the 81 was the beginning of the j motors,differant head with bigger ports that came stock with the cv style carbs
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- notaduc
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- notaduc
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- notaduc
- PLUMMEN
quick somebody send wiseco and mtc a note,theyre still listing their pistons as 73-80 being for the kz motors.Both stiles of engines were available in 1981, the "J" and the MK-II
and their 81-96 pistons being for j and gpz series motors! :laugh:
