kz1000 + bs34 cv carbs/pods clarification.
16 Jan 2011 12:17 #422719 by notaduc
I have read at least a half dozen posts about this now and someone keeps mentioning "mods to carbs beyond jetting" but never is specific.
Id like to run bs34's with either individual pods or the larger ones with the dual openings that you run two filters total, possibly with velocity stacks.
I have a motor with no carbs, and I am leaning this way because I am familiar with cv carbs, but it seems like a lot of you guys are strict slide carb folks, really any input is good.
My goal isnt to make the most power possible, just smooth and reliable.
1980 (mostly) KZ1000
16 Jan 2011 12:23 #422721 by PLUMMEN
Replied by PLUMMEN on topic kz1000 + bs34 cv carbs/pods clarification.
measure the i.d of the intake ports on the cyl head ,now measure the i.d of the carbs on the motor side.
if your running a 73-80 motor with stock ports your basically hitting a brick wall with the airflow.if it was a gradual transition it wouldnt be so bad,but its not. B)
16 Jan 2011 12:37 - 16 Jan 2011 12:38 #422724 by otakar
Replied by otakar on topic kz1000 + bs34 cv carbs/pods clarification.
Hay Plum, It's actually not as bad as you may think. The carb dimensions are obvious, 34mm ID and 40mm OD. The blending can be done by grinding a stock set of KZ900/1000 manifolds. Setting up the carbs to work with those motors and pods is a bit more difficult however. Making them respond properly and to jet them right takes experience with the configuration and those particular carbs. Wit those earlier stock motors I would use a set from a GPz750. The needles and needle jets will be about the closest for that amount of vacuum.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 16 Jan 2011 12:38 by otakar.
16 Jan 2011 12:44 #422727 by PLUMMEN
how do you use stock kz boots? 29s are biggest carbs ive ever fit into them B)
16 Jan 2011 12:49 - 16 Jan 2011 12:50 #422730 by otakar
A DIE-GRINDER :woohoo: ;) :silly: Yes it will take a bit of grinding with a stone. 750/4 boots will work also, with a bit of modification. Back in the day, we used those boots with 33mm and 34mm smoothbores all the time.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Jan 2011 12:50 by otakar.
16 Jan 2011 12:54 #422732 by Nebr_Rex
Replied by Nebr_Rex on topic kz1000 + bs34 cv carbs/pods clarification.
What year engine?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
16 Jan 2011 13:07 #422740 by notaduc
Replied by notaduc on topic kz1000 + bs34 cv carbs/pods clarification.
its an 80 fi engine that has the earlier carb head.
16 Jan 2011 13:16 #422741 by otakar
Is this the 80 Classic? that had the fuel injection?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
16 Jan 2011 13:17 #422742 by notaduc
Yes
16 Jan 2011 13:20 #422745 by otakar
You will obviously have to block off the fuel injection ports and the BS34 carbs will slip right into your existing boots.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
16 Jan 2011 13:21 #422746 by notaduc
The guy I got it from had it setup on 37.5 Dellortos, he admits it was a mess, but made power up top. I have no interest in running them and am looking for a good replacement.
I was considering microsquirting it, as I have had success with it in the past, but I think I want to stick with carbs...
16 Jan 2011 13:22 #422747 by PLUMMEN
it has old style kz head
