kz1000 + bs34 cv carbs/pods clarification.
16 Jan 2011 19:31 #422845 by notaduc
Replied by notaduc on topic kz1000 + bs34 cv carbs/pods clarification.
I thought the early 80's kz1000 cv carbs were all the same.
I think I meant gs1000.
1980 (mostly) KZ1000
16 Jan 2011 19:48 - 16 Jan 2011 19:50 #422846 by otakar
Replied by otakar on topic kz1000 + bs34 cv carbs/pods clarification.
The carbs that came on the "J" series heads were needled and jetted for a head and engine that flowed quite a bit more than the earlier engines. The 750 head flows about as well as the earlier 900/1000 head. The big difference are the needles and needle jets as I mentioned before. Those components are impossible to find by themselves and even if you could they are (were) priced out of this world. If the head is stock you will save yourself a lot of tunning headaches with the GPz750 Mikuni BS34 carbs. The KZ750(4) used Keihin CV34 carbs which were junk.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 16 Jan 2011 19:50 by otakar.
16 Jan 2011 19:56 - 16 Jan 2011 19:58 #422848 by otakar
I have built quite a few of the BS34 Mikuni carbs over the years and learned to really love them. At the same time learned to hate the Keihins. I run a set of the Mikuni BS34s on my Built GPz1150 with .420 cams and oversize valves and flowed head and I will put my bike up against anything that runs smooth-bores on the street.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Jan 2011 19:58 by otakar.
16 Jan 2011 20:13 - 16 Jan 2011 20:16 #422852 by Kraz1
Replied by Kraz1 on topic kz1000 + bs34 cv carbs/pods clarification.
I'm up for that, GPz1150 vs GS1150 with mild Cams and 40mm Radial Smooth Bores for the "Street". :kiss:
GS1150 <Clicky
Last edit: 16 Jan 2011 20:16 by Kraz1.
17 Jan 2011 12:27 #422988 by PLUMMEN
Replied by PLUMMEN on topic kz1000 + bs34 cv carbs/pods clarification.
otakar wrote:
That is not an older stile head. That is still a MKII head from 1979-81. You should have no problem using the cv34 carbs. As I mentioned before, get a Mikuni set from a GPz750.
thats the same head as a 79-80 ltd or kz,unless he plugged the injector ports.
the 81 was the beginning of the j motors,differant head with bigger ports that came stock with the cv style carbs
17 Jan 2011 12:45 #422992 by otakar
Both stiles of engines were available in 1981, the "J" and the MK-II
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
17 Jan 2011 13:40 #423018 by notaduc
I am sure it is not the FI head, how can I tell if it is the later head? Doesnt it drop the compression drastically? Require some sort of cam chain mod?
17 Jan 2011 16:01 #423061 by otakar
looking at your pictures, it is the standard MK-II head.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
17 Jan 2011 16:02 #423065 by notaduc
That is what the guy I bought it from said. His recommendation was get a set of smoothbores set up right. I think I am just scared because I have never used them before.
17 Jan 2011 17:33 - 17 Jan 2011 17:34 #423111 by otakar
No eBay APP ID and/or Cert ID defined in Kunena configurationIf the bike/engine is mostly stock than the BS34s are great carbs. Here are some I found on eBay. These would be a direct bolt on. The spacing on them is exactly the same as on your head.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Jan 2011 17:34 by otakar.
17 Jan 2011 17:40 #423115 by notaduc
I was looking at the same set, are the all black stock? Or di someone rattlecan those?
17 Jan 2011 18:09 #423128 by PLUMMEN
quick somebody send wiseco and mtc a note,theyre still listing their pistons as 73-80 being for the kz motors.
and their 81-96 pistons being for j and gpz series motors! :laugh:
