- Thank you received: 2098
Over it!
17 Oct 2010 03:50 - 17 Oct 2010 04:15 #407155
by Patton
Replied by Patton on topic Over it!
I use fuel line obtained from a local tool rental business.
These places usually keep the high quality small fuel line on hand to minimize maintenance issues with their inventory of rental items.
Is usually available in kink-resistant version with desired smaller o.d. and appropriate i.d. size.
It's not the cheap stuff.
Tygon hose may be acceptable as a second best choice, imo.
If opting for Tygon, the braided version probably isn't necessary, as it's designed for pressurized lines.
Last edit: 17 Oct 2010 04:15 by Patton.
17 Oct 2010 04:05 - 17 Oct 2010 04:17 #407156
by Patton
Note the grey color fuel line.
The thicker black hose is oil cooler line.
[Click on image to enlarge view.]
Last edit: 17 Oct 2010 04:17 by Patton.
- lobstermobster
- Thank you received: 1
17 Oct 2010 15:53 #407257
by lobstermobster
1981 kz650 w/ flux capacitor
Replied by lobstermobster on topic Over it!
So youre suggesting I turn the "T" shaped inlet upside down and loop the fuel down and back up? When my tank is kinda low on gas will there still be enough pressure to push the fuel back up?
17 Oct 2010 19:29 #407319
by Patton
17 Oct 2010 19:30 #407321
by Patton
- lobstermobster
19 Oct 2010 06:13 #407563
by lobstermobster
