I want to upgrade any input?
- kaw a bong a
- Have a 1978 kz 650 b and a 1976 kz 900z1ltd
1978kz650b 1976kz900 first bike 1979kz 400
- keith1
- Thank you received: 2
- kaw a bong a
- keith1
- otakar
just my .02, but thats a lot of carb for anything less than a 1075 with big cams(410) or better......even then , streetability would suffer......i m curious what others think.......
+1 I agree. Bit to much for that motor. you will loose more than you will gain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kaw a bong a
- keith1
- keith1
the shop that sells them says they will jet them for you're bike,they also say they will work for up to a 1197cc and the 36s' are for bigger than that,but they also say they are streetable at slow speeds too.or should I be looking at some 29s?I dont plan on going bigger bore,but liked the way the 34s look,and thought I might get some more power .
if you had 1197 with cams, i would go for it.....1015....nope
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
- Thank you received: 104
- kaw a bong a
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
