82 KZ 750N1 Spectre
- xmoney
05 Oct 2010 18:53 #404366
by xmoney
1992 Harley Davidson FXDC Full Custom
1982 KZ 750 N1 Cafe project
1970 BSA Thunderbolt OIF W/ Lightning twin carb Head Bobber/ Cafe Stayle (Project )
Replied by xmoney on topic 82 KZ 750N1 Spectre
I think I am going to do some research on this. I would like to see at least these carbs run (if I can get them jetted correctly ). I have had some pretty good luck with this sort of thing in the past. The cylinder head has been worked;so it should just be a matter of jetting it. I do need to see what these things flow! I noticed your avatar. Are you a Marine ? Jeff
- otakar
05 Oct 2010 19:03 #404370
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 82 KZ 750N1 Spectre
Both the carb sets you have should be Keihins. Most of us here try to stay away from them and stick with Mikuni because of part availability and cost of re-builds. The Mikuni carbs are much more friendly to modifications on engines and have broader adjustability. I have worked on Keihin carbs in the past and do not like them. You will most likely have to do a lot of tinkering to get them to perform the way you want.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- xmoney
05 Oct 2010 19:14 #404374
by xmoney
otakar wrote:
Thanks for the advice . I will see what can be found.
- xmoney
10 Oct 2010 16:18 - 10 Oct 2010 16:22 #405761
by xmoney
xmoney wrote:
Ok here are the 900 carbs all mounted up and throttle is working .
I will get some this week. Thanks for the help. That is a nice set !
Last edit: 10 Oct 2010 16:22 by xmoney. Reason: added message
