82 KZ 750N1 Spectre
- xmoney
1992 Harley Davidson FXDC Full Custom
1982 KZ 750 N1 Cafe project
1970 BSA Thunderbolt OIF W/ Lightning twin carb Head Bobber/ Cafe Stayle (Project )
- xmoney
- xmoney
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- xmoney
- xmoney
- otakar
Thanks Guys ! I appreciate all the great responses. I do have them mounted for now. I solved the problems of the spacing with some mods between the 2 pairs. I will get some more photos posted of the carb assy once I pull it back off the engine. I am looking at the Gpz carb assy's now. What major mods need to be done other than jetting if I decide to run the Eliminator carbs?
??????? never attempted those. They are set up for a higher RPM engine therefore most likely completely different.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- xmoney
