- Thank you received: 1
gas in exhaust
- hocbj23
- Visitor
03 Oct 2010 09:39 #403750
by hocbj23
Replied by hocbj23 on topic gas in exhaust
on a more solemn and serious note( if there is such a thing around here) also check ur petcock.Mine was shot and allowing gas to leak into the carb bowls which then filled up and leaked all over everything.bj
- hypnohio
03 Oct 2010 09:42 #403752
by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
Replied by hypnohio on topic gas in exhaust
that's going to be my next step. there is some leakage around the petcock. thanks.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- hocbj23
- Visitor
03 Oct 2010 09:45 #403753
by hocbj23
good luck-ride safe.bj
- hypnohio
03 Oct 2010 10:17 #403767
by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
you also.
sk
sk
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- Oliver
03 Oct 2010 10:54 #403771
by Oliver
Things I currently own
1983 kz550ltd owned 10 years
1982 kz1100a2 just bought as winter project
1967 vw beetle 1775cc first car owned 25 years
Replied by Oliver on topic gas in exhaust
No matter what it is, change your oil Like TexasKZ said.
- hypnohio
03 Oct 2010 13:03 #403804
by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
will definitely change the oil. took petcock apart and everything seemed fine. somebody didn't put on a hose clamp, thus the leak. carbs next.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- hypnohio
03 Oct 2010 13:03 #403805
by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
- hypnohio
05 Oct 2010 17:25 #404325
by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
I figured out a functional fix, though not a permanent one. If I back off on the choke immediately when the bike starts, no gas in the exhaust. Full choke seems to suck out too much gas-maybe fuel level too high or float problem. will hopefully find out when I look at the carbs, but at least I know how to avoid the initial problem. thanks for all the help.
sk
sk
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
