gas in exhaust
02 Oct 2010 11:12 #403404 by hypnohio
gas in exhaust was created by hypnohio
when I start my '82 kz440 with a full choke gasoline comes blowing out of a little hole in the bottom of the exhaust, right where the straight tube joins the megaphone. It stops when the choke is off. bike starts and idles fine. any ideas what is causing this? thanks.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
02 Oct 2010 14:18 #403443 by TexasKZ
Replied by TexasKZ on topic gas in exhaust
My first suspicion would be that one of the needle and seat (carb float) valves is leaking a bit. Is there fuel in the engine oil?
If so, do not pass GO, do not collect $200. ;)
Fix it before you ride it again. If enough gasoline gets into the crankcase, the engine can hydro-lock, turning the whole thing into an attractive boat anchor...........
  • larrycavan
  • Visitor
02 Oct 2010 14:38 #403448 by larrycavan
Replied by larrycavan on topic gas in exhaust
Are you sure it's not just condensation in the pipe. If raw gas was coming out like that I doubt it would idle.
02 Oct 2010 16:26 #403469 by 650ed
Replied by 650ed on topic gas in exhaust
I agree. Catch a little in a bottle cap and (carefully) see if it will light with a match. Ed
02 Oct 2010 16:31 - 22 Jan 2013 01:42 #403478 by H1Vindicator
Replied by H1Vindicator on topic gas in exhaust
Last edit: 22 Jan 2013 01:42 by H1Vindicator.
  • hocbj23
  • Visitor
02 Oct 2010 16:42 #403488 by hocbj23
Replied by hocbj23 on topic gas in exhaust
or see how fast u can do the 100 meter dash if the sh-- catches fire and ignites ur bike--damn.bj
02 Oct 2010 18:02 #403518 by hypnohio
Replied by hypnohio on topic gas in exhaust
Thanks for all the feedback everyone. I'll check it out first thing in the morning (wearing my running shoes in case I have to run really fast.) I'm assuming that those little holes in the pipes are there for that very reason, i.e., to let out moisture.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
02 Oct 2010 18:05 #403521 by hypnohio
thanks for that scary bit of info! I'll check it out for sure.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
02 Oct 2010 18:07 #403523 by hypnohio
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
03 Oct 2010 09:13 #403732 by hypnohio
Well, it's definitely gas coming out of there, and with the engine fully choked it's pouring. when I put it to 1/2 choke it will often rev up to 3500 rpm all on its own, but with no choke it seems to be normal, i.e. no gas coming out. As I mentioned before, it starts and idles great, though there is a bit of whitish exhaust occasionally. I guess it's time to take the carbs off and check it out. also noticed some leaking around the petcock. thanks for all your help, and any further ideas greatly appreciated. I haven't checked the oil yet for signs (smells) of gas in there.
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
03 Oct 2010 09:15 #403733 by PLUMMEN
Replied by PLUMMEN on topic gas in exhaust
:woohoo:
03 Oct 2010 09:19 #403735 by hypnohio
that's kind of what it looked like.......:laugh:
1982 KZ440 LTD
2003 EN500 C
2006 Virago 250
